Hcinarli
Participantsolved thanks.
Hcinarli
ParticipantIs it not possible to do without the elastic report What I want to do is to record the data I read from my modbus device on a daily basis I tried to change the table properties, but it did not work as I wanted. In the properties of the channel I want to keep the daily data, daily data is also checked in the archive mask field, but only the hourly archive is kept in the table, thanks in advance.
Hcinarli
Participanthttps://i.imghippo.com/files/aRbF4329aVw.png
https://i.imghippo.com/files/NtXP9856NQ.png
As it can be seen in the fields I marked in the images, I can show the data I read from my modbus device hourly history data, in the same way, I created a table to show the data I read from my modbus device daily, I made 1440 minutes instead of 60 minutes from the table settings, and although dailydata is marked in the archive mask field in the relevant channel for the daily, I cannot show the daily data in the table editor. My goal is to record the data I read from my Modbus Device daily as in hourly data.
Translated with DeepL.com (free version)
Hcinarli
ParticipantThanks solved, but I want to show the incoming data without commas. I tried D. and General formats but it didn’t work.
Incoming data 6,535,365
I want to show 6535365
Hcinarli
ParticipantFor example, as the next step, when I cannot access the device, I want to print the device is not accessed ?
Hcinarli
ParticipantNow I understand and solved it, thanks for the help, I’m sorry if I had difficulty understanding, is there a resource you can recommend to learn rapidscada?
Hcinarli
I understand, I edited it as in the image, but where should I enter the status of normal or error, that is, the area specified as (reserved name for driver), that is, how will I detect the status through this channel? How should I proceed now, as in the image Thanks in advance.
Hcinarli
I want to create a channel in this way and change the led colour according to its status, but I can’t do it.
Hcinarli
ParticipantI want to create a channel in this way and change the led colour according to its status, but I can’t do it.
Hcinarli
ParticipantAs you stated, I added a channel to my driver, I edited it as Tag Number 1 Tag Code Error, I entered the channel I added as input to the led object in the scheme editor and made conditions, but the led did not change colour, can you explain a little more descriptively with visuals if possible?
Hcinarli
ParticipantIs there any way to get the warning of the device that I cannot access without writing a script in the schema editor? If I can only do it with script, can you share a script example?
