rajatdas2005
ParticipantHi in Rest API GET call I am (http://192.168.1.2:10008/Api/Main/GetCurData?cnlNums=101) and POST (http://192.168.1.2:10008/Api/Main/SendCommand).
Instead of these cnlNums=101, is it possible to do GET and POST call by the variable name itself ?
rajatdas2005
Using DrvMqttPublisher, not able to create any channels.
rajatdas2005
ParticipantAnd just for publishing data DrvMqttPublisher only will be sufficient ?
rajatdas2005
ParticipantFor both publish and subscribe different topics over MQTT do I need to use both MqttClient and MqttPublisher driver/device ? or only using MqttClient I can do both publish and subscribe ?
rajatdas2005
Participantplease provide the steps so that I can expose the rapid-scada opcua client data via MQTT to the external world.
rajatdas2005
ParticipantThank you…So by using DrvMqttPublisher, will I be able to publish scada data to a standalone mqtt broker, so that other application can subscribe it to get the data ?
can you mention the steps to enable and communicate Mqtt Publisher in rapid scada.-
This reply was modified 2 years, 2 months ago by
rajatdas2005.
rajatdas2005
ParticipantNow the port is opened, and I am able to deploy the project in the remote linux machine. Thanks a lot for help.
rajatdas2005
Participantss -ntulp
Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port Processtcp LISTEN 0 512 0.0.0.0:10008 0.0.0.0:*
tcp LISTEN 0 10 0.0.0.0:10003 0.0.0.0:*
tcp LISTEN 0 4096 0.0.0.0:10002 0.0.0.0:*
tcp LISTEN 0 4096 0.0.0.0:10000 0.0.0.0:*
tcp LISTEN 0 10 0.0.0.0:10006 0.0.0.0:*
tcp LISTEN 0 10 0.0.0.0:10005 0.0.0.0:*
tcp LISTEN 0 10 0.0.0.0:10004 0.0.0.0:*rajatdas2005
Participantuser@rajat:/var/log/scada/ScadaAgent/Log$ cat ScadaAgent.log
2024-09-09 06:03:37 [rajat][root][ACT] Agent 6.2.0.1 started
2024-09-09 06:03:37 [rajat][root][ACT] Start logic processing
2024-09-09 06:03:37 [rajat][root][ACT] Start listener on port 10002rajatdas2005
ParticipantEarlier I have installed rapid-scada in the remote Linux machine, and all the 4 services is running. firewall I will check.
@Mikhail, I am not able to deploy the project in the remote Linux machine, so where to check the ScadaAgent.log file ?rajatdas2005
ParticipantI am not able to establish connection from Windows to remote Linux machine (It has a public ip). So not able to deploy the project. Next if I simply copy and paste the whole project itself in the remote linux machine, then how to run it in that machine ?
rajatdas2005
ParticipantActually this ubuntu server is a remote one, and I access this via ssh with .pem key and ip address. So in the deployment profile secret key section do I need to put the .pem key values ?
rajatdas2005
ParticipantThank you. For this both windows and ubuntu system need to be in the same network ?
rajatdas2005
ParticipantHi Thank you. Current I am building the project in a windows system and while deploying the project the ip section is blank and opening in localhost. Now in this section do I need to put the Ubuntu machine ip and open that in the browser ?
rajatdas2005
Thank you for your reply. From the architectural diagram, it is visible that external applications can communicate only with the rapid scada server. So what will be the correct url so that I can access opcua client variables from an external application via rapid scada server ? -
