r1moore
  • in reply to: x.509 Certificate Authentication #16160
    r1moore
    Do you know where I can find the certificates?
    in reply to: Auto control module not loading #15151
    r1moore
    I also get the following error when saving commands.
    Error saving module configuration:
    Method not found: ‘System.Xml.XmlElement Scada.ScadaUtils.AppendElem(System.Xml.XmlNode,System.String,System.Object)’.
    in reply to: Auto control module not loading #15150
    r1moore
    I have verified the versions are compatible. I noticed every time I upload the configurations in the admin app it erases the contents I added to the ModAutoControl config file and leaves it blank. Any idea why this would be happening?
    in reply to: Rest API integration #15107
    r1moore
    Where can I find an example of a custom driver method for writing data to an input channel?
    in reply to: Rest API integration #15095
    r1moore
    I have created a custom driver and added it as a communication line in the Scada Admin application. I selected my custom driver in the Device Polling tab and ensured its description was displayed correctly. I uploaded the configurations but I am getting the following error in the communication line log: Error reading file [Comm]/[Log]/line003.log: File not found
    What is causing this error?
    in reply to: Rest API integration #15077
    r1moore
    I noticed in the driver documentation it says to use the Class Library template. Where can I find this?
    in reply to: Rest API integration #14994
    r1moore
    I have the code in scada scripts currently but I am unsure how to call it from other tables.
