November 6, 2023 at 12:50 am in reply to: How to use a c# script to process input XML/MQTT message #13594
joii
ParticipantThank you very much for your patient answer
This is the sensor JSON I received, which is/Test1 and/Test2 respectivelyhttps://ibb.co/BL1RY7P
https://ibb.co/dG25pBVHow should the channel be bound to the device? I really hope I haven’t found the corresponding settings
I don’t know if my settings below are correct, or if there are other settings needed. I seem to have no effect following the settings in the picture
https://ibb.co/bsJfnsZNovember 4, 2023 at 12:49 am in reply to: How to use a c# script to process input XML/MQTT message #13590joii
ParticipantThis is my configuration information for this MQTT client. I configured the Javascript file and Sub Items, and successfully called Javascript to print the statements in the JS in the Line log. However, I also configured a Test2, but did not receive the sensor values, which I am very confused about. Here is my configuration
https://ibb.co/fX43JMjAt the same time, how do I display the values I receive on this View? It seems that due to my lack of successful binding channels, I am unable to bind data to Dynamic text
At present, we have encountered difficulties in these two points and hope to receive your help
November 3, 2023 at 8:13 am in reply to: How to use a c# script to process input XML/MQTT message #13583joii
ParticipantHello,Mikhail
Can I take a look at how to manipulate and assign attributes in JavaScript,
And how to display the collected real-time data of JSON on the view -
