Keano
  • in reply to: SendCommand function #13131
    Keano
    Will this be done using the same as the current telegram driver ? Or not
    in reply to: How to set up Telegram #13125
    Keano
    Hi
    I was wondering if it is possible to write commands from telegram to rapid for example if I click a button appearing under my notification on telegram it would send a command back to rapid scada and trigger something.
    in reply to: SendCommand function #13119
    Keano
    Is it possible to send a command from a button setup on my telegram bot for example, I get a message Alerting me when the generator receives an overvoltage alarm, I would like to click a reset button under my message alerting me that then sends a Modbus signal to reset the generator?
    in reply to: Copy and paste notifications #13024
    Keano
    Hi I seem to be getting this problem in my automatic control module logs.
    Sending commands skipped
    Why does this happen and how can I solve it.
    in reply to: How to set up Telegram #13022
    Keano
    in reply to: Copy and paste notifications #12996
    Keano
    I Found it and have been playing around with it but it seems like even if I copy and paste triggers and commands and then change the names and values I still only get one folder instead of two.
    <?xml version="1.0" encoding="utf-8"?>
    <ModAutoControl>
      <TrGroups>
        <TrGroup active="true" name="Comap Controllers" />
        <TrGroup active="true" name="Comap Controllers 2" />
        <TrGroup active="true" name="Gen 1">
          <Trigger id="5" active="true" name="Gen 1 Oil Pressure switch" type="CnlDataTrigger">
            <CnlDataTriggerProps>
              <CnlNum>101</CnlNum>
              <ChkCnlVal>true</ChkCnlVal>
              <CnlValCond>
                <CompareOperator1>Equal</CompareOperator1>
                <CompareArgument1>1</CompareArgument1>
                <LogicalOperator>None</LogicalOperator>
                <CompareOperator2>LessThan</CompareOperator2>
                <CompareArgument2>0</CompareArgument2>
              </CnlValCond>
              <Deadband>0</Deadband>
              <ChkCnlStat>false</ChkCnlStat>
              <CnlStat />
              <Delay>0</Delay>
              <Repeat>0</Repeat>
              <RepeatCnt>0</RepeatCnt>
            </CnlDataTriggerProps>
    		<Trigger id="6" active="true" name="Gen 1 Oil Pressure switch" type="CnlDataTrigger">
    		</Trigger>
    		  <CnlNum>201</CnlNum>
              <CnlValCond>
              </CnlValCond>
              <CnlStat />
              <Delay>0</Delay>
              <Repeat>0</Repeat>
    		<Commands />
        </Trigger>
    	</TrGroup>
      </TrGroups>
    </ModAutoControl>
    As you can see here I have a trigger and I command for two of the same things on diffrent channels but when I run it I dont get a error I ony get my original “Gen 1 ” trigger and command.
    in reply to: Copy and paste notifications #12991
    Keano
    Where Do I find the xml file
    in reply to: How to set up Telegram #12979
    Keano
    Good Afternoon I am encountering the same issue as the person above. I get the following error. “2023-07-10 17:13:03 Communication session with the Device 1 “Telegram Bot”, type: KpTelegram
    Send request:
    https://api.telegram.org/bot6360611251:AAHMbs73bPeHHluELcDKCT7pxLyPlmSMZfA/getUpdates?offset=0&timeout=0&allowed_updates=message
    Error executing request: The operation has timed out
    I went and made sure that everything is setup according to your guide but it is still not working.
