Good afternoon.
I have proceeded to make the structure that you indicate me but I do not understand how you link the connectors to the same channel.
I have screenshots but I can’t attach them in the post.
I have even compressed the application so you can have a look at it.
When you tell me to edit the ScadaAgentConfig.xml file and change the instance name I don’t understand the procedure since there is only one file in the program “Rapidscada” it is common for all the projects.
Thanks in advance for your help
