naser
  • in reply to: Export data to SQL #12389
    naser
    hello,
    can you explain how I enter IP address in Server textbox ?
    in reply to: Export data to SQL #12309
    naser
    How I Connect Microsoft SQL Server With Rapid Scada Idid Setting as per the attachment but not working
    Export To DB
    Export To DB
    ModDbExport.log
    ModDbExport_001.log
    2023-03-23 09:39:49 Error connecting to DB:
    MySql.Data.MySqlClient.MySqlException (0x80004005): Unable to connect to any of the specified MySQL hosts. —> System.Net.Sockets.SocketException (0x80004005): No such host is known
    at System.Net.Dns.GetAddrInfo(String name)
    at System.Net.Dns.InternalGetHostByName(String hostName, Boolean includeIPv6)
    at System.Net.Dns.GetHostEntry(String hostNameOrAddress)
    at MySql.Data.Common.MyNetworkStream.CreateStream(MySqlConnectionStringBuilder settings, Boolean unix)
    at MySql.Data.Common.StreamCreator.GetStream(MySqlConnectionStringBuilder settings)
    at MySql.Data.MySqlClient.NativeDriver.Open()
    at MySql.Data.MySqlClient.Driver.Open()
    at MySql.Data.MySqlClient.Driver.Create(MySqlConnectionStringBuilder settings)
    at MySql.Data.MySqlClient.MySqlPool.CreateNewPooledConnection()
    at MySql.Data.MySqlClient.MySqlPool.GetPooledConnection()
    at MySql.Data.MySqlClient.MySqlPool.TryToGetDriver()
    at MySql.Data.MySqlClient.MySqlPool.GetConnection()
    at MySql.Data.MySqlClient.MySqlConnection.Open()
    at Scada.Db.DataSource.Connect()
    at Scada.Server.Modules.DbExport.Exporter.Connect()
    2023-03-23 09:39:51 Error connecting to DB:
    2023-03-23 09:39:52 Error connecting to DB:
    2023-03-23 09:39:53 Error connecting to DB:
