feltduck
ParticipantAnd since I updated the SCADA some devices started to fail too.
feltduck
ParticipantYes, sorry. This is the error that is showing.
https://tinypic.host/image/2dXxa
But I want to resolve both problems to do some tests.
feltduck
ParticipantI updated to 6.1.3 and now I’m having this error
feltduck
I’ve been trying this one and I didn’t get any result. Maybe I’m not doing it well, how can I send a command to the DB export module?feltduck
ParticipantSorry for the confusion, I already fixed that problem. I was asking you how to check the historic of 15 days ago from now.
feltduck
ParticipantWhat do you mean with “Get the correct raw data”?
This reply was modified 3 years, 6 months ago by
feltduck.
feltduck
ParticipantAnd how can I check the data in a specific hour? E.g I got a NULL value because the devices get disconnected at 10:15 and I want to check at that hour and replace that NULL for the real value of the device at 10:15.
Sorry if I’m asking too much.
feltduck
ParticipantOk, thanks for the information. The other question that I have is when a device get disconnected the data is stored like this:
https://tinypic.host/i/oW7LIq
I want to check the data that is stored in the device at that hour and replace it.feltduck
ParticipantI’m sorry, BBDD it’s the acronym for data base on my language.
My timezone is Madrid GMT+2feltduck
ParticipantI need to set the connection on shared because I’m working with more than 1 device.
The communication is working well but when the SCADA stores the data in the BBDD it has a problem with the datetime.
E.g:
In this screenshot the datetime is at 10:00 when the real time is 12:15.
https://tinypic.host/i/ohzhpAThen at 12:30 it’ll store the data with the datetime at 10:15 in the BBDD.
feltduck
ParticipantHere it is:
https://tinypic.host/i/ohOmh4feltduck
ParticipantHi, sorry for the delay.
These are the communicator settings:
https://tinypic.host/i/ohOeKkAnd these the channels:
https://tinypic.host/i/ohOcsDI’m not using an user interface.
feltduck
ParticipantWhich settings do you want to see?
feltduck
The error this is the error:
2023-03-23 08:25:35 [DESKTOP-U1FIFOL][DESKTOP-U1FIFOL$][ERR] Error calling the MakeReady method of the MinCopy archive:
System.FormatException: String is not hexadecimal.It happens when I change the server, username and password.
