gabeirinhas
Viewing 15 posts - 1 through 15 (of 54 total)
  • in reply to: Mail settings #14134
    gabeirinhas
    in reply to: Formula lowestValue #14109
    gabeirinhas
    The real problem is that when I upload changes to the server, the last valid value is reset.
    If this didn’t happen, I could implement this formula in a natural way, so I could add “DayStarted() function”.
    Resetting the server on a scheduled basis at 00:00 I do this so that if I make changes to the server, they are not updated until 0:00 and it does not affect the performance of the formula.
    in reply to: Formula lowestValue #14099
    gabeirinhas
    Attached is an updated formula.
    The approach I use to update the value daily is to give a server reset scheduled for 00:00,
    The previous formula was stored globally so it did not allow linking more than one channel.
    The approach is as follows:
    1. Implement the following formula in the formula dictionary ( it is put that the value cannot be less than -170, for reasons of errors in a transmitter):
    Dictionary<int, double> lowestValues = new Dictionary<int, double>();
    public double LowValue(double val, int channelNumber)
    if (!lowestValues.ContainsKey(channelNumber))
    lowestValues[channelNumber] = val;
    else
    if (val >= -1700)
    lowestValues[channelNumber] = Math.Min(lowestValues[channelNumber], val);
    return lowestValues[channelNumber];
    2. Use the following formula for a “Real” channel:
    LowValue(Cnl, 1090) / 10
    # Where 1090, is the channel number,
    I hope it helps and someone is able to improve it so that the last recorded value is not lost when the server disconnects.
    Regards
    • This reply was modified 2 years, 8 months ago by gabeirinhas.
    in reply to: Using KpDBImport and SQL #11747
    gabeirinhas
    Thank you, it has helped me
    To be able to dump the values ​​as I need them,
    I must create a new table, where each of the columns corresponds to the value that I want to show,
    Thanks for your help,
    greetings
    in reply to: Using KpDBImport and SQL #11743
    gabeirinhas
    I have questions about dbimport,
    1. How could I do to communicate a sqlite database with the rapid scada environment. I have been trying without success.
    2. When I communicate with a sql server database,
    in “data retrieval”, I ask for the following fields as an example.
    SELECT value FROM tags WHERE name = ‘LT1’ ORDER BY stamp DESC
    SELECT value FROM tags WHERE name = ‘PT1’ ORDER BY stamp DESC
    However, I only get in tags data, the first data. How can I get both data.
    Thanks in advance, greetings
    in reply to: JavaScript API example custom page #11659
    gabeirinhas
    Ok, I know where the mistake was
    Path: http://localhost/Scada/MyPage/MyPage.html
    Regards
    in reply to: JavaScript API example custom page #11645
    gabeirinhas
    Yes, it is configured in the same way.
    I used the same example and it doesn’t work either,
    Copy the custom directory into C:\SCADA\ScadaWeb\
    Path = C:\SCADA\ScadaWeb\custom\MyPage.html
    View Type = WebPageView
    Title = HelloWorld\My Page
    Upload the configuration.
    It keeps refreshing the page continuously
    in reply to: JavaScript API example custom page #11640
    gabeirinhas
    I ve the following error, press f12
    Landing.aspx?viewID=110:40 Not allowed to load local resource: file:///C:/SCADAScadaWebMyPage_AlsaP%C3%A1gina-1.html
    (anonymous) @ Landing.aspx?viewID=110:40
    setTimeout (async)
    i @ jquery.min.js:2
    fireWith @ jquery.min.js:2
    ready @ jquery.min.js:2
    J @ jquery.min.js:2
    thank u in advance
    in reply to: JavaScript API example custom page #11639
    gabeirinhas
    Ok, I have copied it to the directory and the error persists.
    in reply to: JavaScript API example custom page #11637
    gabeirinhas
    Where is the ClientApiSvc.svc file located?
    I have the same error, the page keeps loading constantly.
    gabeirinhas
    Sorry, I didn’t see it updated,
    It works, thanks for the help
    in reply to: Omron Fins Driver (Ethernet) #11429
    gabeirinhas
    This is as far as I have got,
    The development of the memory areas that are read and written must be written to the dll.
    I hope it helps those of you who know more about this to do it better,
    https://drive.google.com/file/d/1NdM3AiUi2aXZfQgFRhetR87KOEv-2O0o/view?usp=sharing
    Thank you, best regards
    in reply to: Omron Fins Driver (Ethernet) #11410
    gabeirinhas
    in reply to: Omron Fins Driver (Ethernet) #11409
    gabeirinhas
    I think I have found a better way,
    I have seen the following development in visual studio,
    https://www.codeproject.com/KB/system/878194/mcOMRON_demo.zip
    And I have seen the following link from rapid scada
    https://rapidscada.org/device-drivers-development/
    I have tested the project in visual and it works correctly,
    This development could be implemented as a rapid scada driver ?.
    Could you help me with the development ?,
    Thank you,
    in reply to: Omron Fins Driver (Ethernet) #11382
    gabeirinhas
    It sure helps,
    You’ve made my day,
