Han
  • in reply to: Database SQL usage #9321
    Han
    Hi, I have been busy with other things recently. Which version of Rapid SCADA is needed?
    in reply to: Database SQL usage #9141
    Han
    I’m sorry, my English is poor, and I don’t know if the grammar I described is correct. I use Google Translate.
    in reply to: Database SQL usage #9140
    Han
    Hi,Mikhail
    Thank you for your help all the time.
    Sorry, I failed to describe my needs clearly before. I want to write the data (data1, data2, data3…) obtained by Modbus into the SQL table at a frequency of once a minute. The columns of the SQL table are arranged in accordance with the (writing time, data1, data2, data3… ).Retrieving data from Modbus has been successful. But I don’t know how to write SQL in the above arrangement.
    in reply to: Database SQL usage #9128
    Han
    How to declare variables?
    in reply to: Database SQL usage #9127
    Han
    2021-06-22 22:32:13 Establish a TCP connection with :1433
    2021-06-22 22:32:13 Communication session with the Device 2 “SQL2008”, type: KpDbImport
    Data request
    Error executing query: scalar variable “@CnlNum” must be declared.
    Data request
    Data request
    Data request
    in reply to: Database SQL usage #9100
    Han
    Microsoft SQL Server,KpDbImport or ModDBExport;Could you provide the following example ?Thank U
    in reply to: Database SQL usage #9027
    Han
    in reply to: Database SQL usage #9025
    Han
    Sorry, I am a novice, can you provide the usage of @cmdVal and @cmdNum. I want to write the value read by modbus into SQL, for example, write the value of channel 101 of modbus into SQL?
    • This reply was modified 5 years, 5 months ago by Han.
    in reply to: Database SQL usage #9016
    Han
    Microsoft SQL Server,KpDbImport,thank you !
