huang
ParticipantFor example, to control the state of the gate, when opening the gate, click the open button to close and then open; when closing the gate, click the close button to open and then close. Can these two actions be implemented in one action?
huang
ParticipantThanks, I want to implement the reset function.
huang
ParticipantHello,Thank you for your answer. We have solved this problem,but there are still questions for you.
For the dynamic picture or toggle component,I do not mean 2 state button.I want a component that can execute 2 events with one click(as the example shown in Figure 1) at a time.Is there any component that realizes this kind of function at present, if so, how to use it, if not, can you please develop a button component with this kind of function?
Figure 1:-
This reply was modified 5 years, 7 months ago by
huang.
huang
ParticipantThank you for your help.
The scheme templates didn’t help me.Can you develop or improve this function of passing parameters?huang
ParticipantNot set the Input channel.Can’t the channel number of the data-input channels in the link component properties be passed as a parameter to the dynamic text component in the popup?
huang
ParticipantDear Mikhail,
I have a new question to ask.
Question:configure the link component, the second-level dialog box does not display data, and no pop-up box appears when the button is clicked.
Operation process:Configure the View ID in the link component properties as the scheme index displayed in the secondary dialog, Input channels configure one or more input channel parameters, Target configure the popup, and the component properties of the secondary dialog will not be configured. As a result, the text component in the secondary dialog box does not display data, and the button component clicks without a pop-up box.
Screenshots:
Configure link properties as shown in Figure 1:
https://ibb.co/4gVt6mt
The secondary dialog box is displayed as shown in Figure 2:
https://ibb.co/N7nBTzy
Please show a correct example, preferably with a screenshot of the configuration steps.Thanks! -
