Ashashash
  • in reply to: Migrating V5.84 projects to V6 #17176
    Ashashash
    About 11000
    in reply to: Migrating V5.84 projects to V6 #17159
    Ashashash
    Thank you, files found.
    Still struggling how to use it 🙁
    Trying to run the ProjConv5to6.exe, but nothing happens, no new configuration files created.
    Possibly there is some more detail manual, or video…
    in reply to: Migrating V5.84 projects to V6 #17130
    Ashashash
    I have many channels, but can’t find converter files to download. Conv5to6.exe and similar.
    Please repeat the link.
    in reply to: Displaying string instead of input #15694
    Ashashash
    Ok, for example:
    if input 1001 value is:
    434.081, I need text to be displayed “Error +10V ref. sensor system : I/O board control cabinet”;
    233.001 -General warning message : software update required;
    62.031 -Feeding fault : System circuit breaker off;
    60.010 -Mains failure : Overvoltage L1+L2+L3;
    60.028 -Mains failure : Overfrequency (restart).
    And so on. Few hundred lines like this.
    Also for different equipment different set of texts
    in reply to: Displaying string instead of input #15689
    Ashashash
    Hello Mikhail,
    I use 6.2.1.1 version,
    I need to display text values instead of input numberic value,
    But tried Formats, also Units. Seems all options are limited to text size 1000 symbols.
    Is there an option to use 20000 or more symbol formula?
    in reply to: Displaying string instead of input #8253
    Ashashash
    I only tried to create a formula:
    https://ibb.co/qj0067F
    • This reply was modified 5 years, 9 months ago by Mikhail.
    in reply to: Displaying string instead of input #8245
    Ashashash
    I tried to use option 2,
    entered EncodeAscii(Cnl < 2 ? “Running” : “Not Running”) in formula,
    but received server error. What I am doing wrong?
    Line 514, column 1: error CS1520: Method must have a return type
    Line 514, column 19: error CS1031: Type expected
