zzz
ParticipantOK, got it. So that is .net core which I alomost lost track of.
Does V6 and V5 server communication API has a lot of major change ?
zzz
ParticipantCould you explain what you mean by abandoning Mono ?
Do you mean abandon .NET for Administrator, or are there are other alternative for Mono on Linux?zzz
ParticipantI was wondering why not use starting adress as the signal id in the first place (they are numeric, sequential, not continuous but unique, ).
While the V6 solution sounds good, I just wonder if the tags can be sorted easily by register start address, either automatially/by default/manually ?
Having a labeled register block layout overview is a realy nice thing. I think the template editor in V5 seems close to that, even if not perfect.
June 24, 2021 at 1:01 am in reply to: Same configuration different command frame on Windows and Linux #9152zzz
ParticipantKind of emergency here, due to the system freeze issue. Maybe I can create a minimum setup to replicate the issue, after my system immegration work is done…
June 23, 2021 at 3:17 am in reply to: Same configuration different command frame on Windows and Linux #9138zzz
ParticipantNope. Windows was using … maybe the last release not current relese or maybe even older. Linux is using lastest release, as this thread was started, on official site for Linux.
I was also wondering if that what Linux fault. ButBecause the immigration was caused by a windows corp. security software updated that causes ramdom windows freeze (unacceptable for control pc), I pulled the latest dev branch code and compile the KpModbus module, copied it to Linux, it didn’t work. I copied it to Windows, RS on windows stopped working either.
The frame hex code in log on both machine are identical – wrong data, different from previous Windows frame.Working Frame Sent on Windws
03 7b 00 00 00 0B 0E 10 02 0E 00 02 04 9F 6F 46 9A || || 2WORD || 4bytesWrong Frame sent on Linux
00 79 00 00 00 0F 0E 10 02 0E 00 02 08 9F 6F 46 9A 00 00 00 00 || || 2WORD || 8bytes?If I set element qty to 1, the trailling 0s are gone, the byte count become valid, but the register count will be 1, which should be 2 (1 float =2 WORD = 4Byte).
As was explain in my last post, I am confused what ElemCount was supposed to mean here, ElementReigsterCount/WORDCount or ElementCount, thus I am not sure what’s the correct fix, so I just replace
ModbusUtils.GetDataLength(ElemType)with 2. then it works, on both linux and windows, the generated request frame become
}}}If ElemCount was supposed to mean ElementCount, there is another issue, in the DeviceTemplate Editor, the
Element Countfield onCommandright pane will change as the user select different element data type, e.g. if4byte floatwas selected,Element Countwill be automatically set to 2, which I supposed means 2 words/register per element, or how does the editor know I send 2 element instead of 1 or 3 Element ?-
This reply was modified 5 years, 4 months ago by
zzz.
June 21, 2021 at 11:41 am in reply to: Same configuration different command frame on Windows and Linux #9120zzz
Participant{{{
ReqPDU = new byte[6 + dataLength];
ReqPDU[0] = FuncCode;
ReqPDU[1] = (byte)(Address / 256);
ReqPDU[2] = (byte)(Address % 256);
ReqPDU[3] = (byte)(ElemCnt / 256);
ReqPDU[4] = (byte)(ElemCnt % 256);
ReqPDU[5] = (byte)dataLength;
}}}I always thought by ElemCnt you mean Element Word Count.
Since In the Device Template Editor, changing the data type, the “ElementCount” field changes, 2 for float, 4 for double, which is number of words.
And in above code ElemCnt is set to reg (WORD) qty in PDU ,
then GetDataLength() shoud reture a constant 2 for non bool types.But if you really mean Elemnt Count, then ReqPDU[3:4] should not be set to ElemCnt.
ElementCount, DataLength etc are very confusing on first glance, initially I guess they are in WORD unit, but it takes more crunching to understand. Maybe it can be reworded.
June 21, 2021 at 10:37 am in reply to: Same configuration different command frame on Windows and Linux #9119zzz
Participante.g.
Send (17): 0B 1A 00 00 00 0B 0E 10 02 0E 00 01 04 46 B8 2E AB
Receive (7/7): 0B 1A 00 00 00 03 0E
Receive (2/2): 90 03
Device error: [03] ILLEGAL DATA VALUE!June 21, 2021 at 10:29 am in reply to: Same configuration different command frame on Windows and Linux #9118zzz
ParticipantI am on developer branch, Github is taking ages to open, please see source, there is byte count is doubled, not sure why.
I am not sure how such problem is not detected in months. I guess, this should be recent change. The Linux instance is setup just yesterday. Windows was long time ago.
ModbusCmd.cs L149
// формирование PDU для команды WriteMultipleCoils или WriteMultipleRegisters
int dataLength = TableType == TableType.Coils ?
((ElemCnt % 8 == 0) ? ElemCnt / 8 : ElemCnt / 8 + 1) :
ElemCnt * ModbusUtils.GetDataLength(ElemType);
}}}ModbusUtils.cs
{{{/// <summary>
/// Gets the length required to store element data depending on the element type.
/// </summary>
public static int GetDataLength(ElemType elemType)
return elemType == ElemType.Bool ? 1 : GetQuantity(elemType) * 2;
}public static int GetQuantity(ElemType elemType)
switch (elemType)
case ElemType.ULong:
case ElemType.Long:
case ElemType.Double:
return 4;
case ElemType.UInt:
case ElemType.Int:
case ElemType.Float:
return 2;
default: // Undefined, Bool
return 1;
June 21, 2021 at 7:57 am in reply to: Same configuration different command frame on Windows and Linux #9114zzz
ParticipantLinux Mono, same data, injected with generator
}}}June 8, 2021 at 3:43 am in reply to: Determing what data is OnCurDataCalculated() fired with ? #9054zzz
ParticipantHi Mik,
I don’t understand what you mean. My question is
for a module that only want to process current snapshot, and ignore any per minute or per hourly averaged data,
when it receives this event, how does it know if the data returned is forcalcDR,calcMinDR,calcHrDR?zzz
ParticipantHi Mik,
I am just looking for cludes or direction for further debugging the issue. The investigation, coding, debuging are all done on my own, and the discussion is on public domain. I don’t see why it has to be charged.
Plus the modautocontrol I already paid did not work as expected. It has problem (now I realized of the same pattern), certain channels in triggered doesn’t work, or not triggered sometimes, while other channels works perfectly. We overcame the problem by removing channels from modautocontrol and resolving the logics only in formular, leaving modautocontrol blindingly forwarding resulting data to output channel.
I think both module are experincing problem of the same nature. Even if I write my own module, or using your new moddbexport module, it’s dubiou this problem can be solved.
zzz
ParticipantI have updated the code to subcribe to both
OnCurDataProcessed()andOnCurDataCalculated(), I didn’t check all the channels, but for channel1403, its very weird: there is no change. The WebStation data looks perfect as usual, and the db data remain scarce.I also tried replacing
OnCurDataProcessed()withOnCurDataCalculated().
Only difference isempty cnldata countin log now is constantly 0.
The issue remains,1403channel has perfect graph in webstation, but export data remains little, only has commited data when it appraches 0, and goes back up after sometime.I suspected I made any mistake in the commit process esp. the
ON CONFLICT DO NOTHINGin sql looks dubous. Thus I hardcoded checks for channel 1403 inEnqueueCurData()function, there is no1403shown in log at all.1403 is a calculation enabled channel, like 1407, but 1407’s data in db looks very OK. I am running out of ideas to try or invesigate. 🙁
zzz.
zzz
ParticipantAfter a bit reading, I get the impression that
OnCurDataProcessed()is event based, and provides both plain and calculated data. (Judging from the current issue, it seems that) based on the loop and event timing, the calculated data may be incomplete.OnCurDataCalculated()is loop based (and paced).
it provide calculated data only (but one has to know the way to tell if the calculated data is averaged, per min, per hour, or original data, not clear how to do it, so I created another question).It seems that if I want to get this fixed now in the current module way,
I need to
– get all calcualted channel number
– subscribe to bothOnCurDataProcessed()andOnCurDataCalculatedevent,
– skip calcuated data inOnCurDataProcessed()
– figure out how to tell hour/minute data from current data ?Do you think the above changes will solve the missing data problem for formula-enabled channels for this module?
Regards,
zzz
ParticipantPS: If I write external client using
Scada.Clientto connect to server externally, rertive data via TCP and export to database, do you think this will solve the formula-enabled cnldata with empty data problem ?Or is this solved in the new export module already ?
zzz
ParticipantHi Mik,
A small suggestion, could you add timestamp to the Srez object upon server reception? I think for some reason, the module self-added timestamp and webstation data timestamp does not align very well…
Uh, I guess I should confirm this before assumption, does
OnCurDataProcessed()hook guarantees formula processing completion ?Regards
