David01
ParticipantIt’s working now.
Thank you very much, Mikhail.
David01
ParticipantHello,
I am having the same problem the original poster had. I am using MySQL 8.0. and I am getting the following error all the time:
2020-12-14 13:49:53 Error connecting to DB MySQL – localhost: Authentication to host ‘localhost’ for user ‘root’ using method ‘mysql_native_password’ failed with message: Access denied for user ‘root’@’localhost’ (using password: YES)
The configuration is really simple, so I don’t understand why it’s not working. I am just trying to connect to the localhost. And I tried it on different projects but the same thing happens all the time. I am currently using the HelloWorld sample project.
My connection string is as follows:
I have been stuck for hours now. I tried everything. I entered the password manually. I tried different users. I tried reconfiguring the MySQL server with a different authentication configuration but then I got an error saying I don’t have the necessary plugins. I also read the answers in the link above but none worked.
Please help.
December 4, 2020 at 1:52 pm in reply to: Storing the result of a formula with Database Import Driver #7662David01
ParticipantThank you. I will look into it.
December 4, 2020 at 9:53 am in reply to: Storing the result of a formula with Database Import Driver #7652David01
ParticipantAlso, is there a way to store multiple data in a single sql table with a single command?
The documentation references the cmdVal variable, but that only sends the value of the current command. So, what if I need to store several variables?
For example, table1 has two columns: variable1 and variable2. I can use an SQL query like this:
INSERT INTO table1(variable1, variable2) VALUES (@cmdVal, null)
I can only pass the data for variable1, that’s why I am forced to pass a null value to variable2. Do I need to create an aditional command to write variable2 on the table?
December 3, 2020 at 1:53 pm in reply to: Storing the result of a formula with Database Import Driver #7642David01
ParticipantYes. I am using Database Import Driver.
I managed to make it work on my own. I think I had done something wrong with the configuration. I am sorry for the trouble.
Now I have another question: Is there a way to store data in a database automatically over time , without a prompt?
If I understood this correctly, the only way to save data is by sending a command, isn’t it?
