kcks66
ParticipantHi Mikhail,
Noted. Thanks for the suggestion.
kcks66
ParticipantHi manjey73,
That’s great. Thank you.
kcks66
Noted. Will give it a try.
kcks66
Currently I am waiting for an publish of instruction steps on how to migrate from V5 to V6. I will definitely want to use V6.
kcks66
Yes. I managed to copy the input channel to the output channel by using data change trigger.
Now can I store a hexadecimal number in an input channel? I want to copy the hexadecimal number in an input channel to an output channel?
kcks66
Ah, I think I didn’t ask the question properly. I wish the output channel send out value always follow input channel as the input channel value is always changed from 1 to 100.
kcks66
Meantime, I tried to use automatic control module to perform quite similar task. My task is straight forward this round.
I want an output channel send out value follow an input channel value; as example input channel 1001 has 15, I want the output channel 2001 to send out 15 also.
I configured automatic control module as below but failed to get the result as I expected.
Pls advice and thank you.
kcks66
Yes, me too. Always get 0.
By the way, thanks for your effort.
kcks66
It is multiple holding register. Example taken from the manual:
The register address to use is 0002 reference frequency:
kcks66
Pls advice for the decimal to hexadecimal conversion issues.
By the way, I have automatic control module installed, could it be used to do the job?
kcks66
I am using V5.8.4. Look’s like the result is not the same in both V5 and V6.
Hi Mikhail,
I changed my output channel command type to Binary. That’s great there is no more error message.
However I entered 30 in web browser but the communicator device page show data is unable to be converted (0001 0000)
This reply was modified 3 years, 2 months ago by
kcks66.
kcks66
I entered 30 in web browser:
But error message occur:
What have I missed out?
kcks66
Next is my device template:
Follow by my output channel:
kcks66
| 31.07.2023 08:59:05 | Code=freq, Data=00010BB8 |
Enter 30 in Web.
Although no, it seems to be enough, I entered 30 into the Web and received the following data in the sent command.YES, this is what I need.
I need to start from beginning step by step follow your instructions.
The formula below is correct?
public byte[] NewFreq()
byte[] freq = BitConverter.GetBytes((uint)Cmd*100);
return new byte[] {0x00, 0x01, freq[1], freq[0]};
}kcks66
I got error message from SCADA Server:
Error calculating standard command value for the output channel 20032: Unable to cast object of type ‘System.Byte[]’ to type ‘System.IConvertible’.
Command is canceledMy output channel formula:
return new byte[] { 0x00, 0x01, freq[1], freq[0]};
}Pls advice and thank you.
