kcks66
Viewing 15 posts - 16 through 30 (of 183 total)
  • in reply to: ChartPro export function #16172
    kcks66
    Hi Mikhail,
    Got it. Thank you.
    in reply to: Telegram send request error #15980
    kcks66
    Hi Mikhail,
    After I changed new 4G modem router and another Telco SIM, the problem solved.
    I think either previous 4G modem router or previous Telco got problem.
    in reply to: Telegram send request error #15963
    kcks66
    Hi Mikhail,
    Yes. same send request error from communicator.
    Today I changed new 4G modem router and different Telco SIM.
    I continue monitor the results.
    in reply to: Telegram send request error #15942
    kcks66
    Hi Mikhail,
    During Telegram send request error:
    Error executing request: The request was canceled due to the configured HttpClient.Timeout of 10 seconds elapsing.
    I tried to send the same request in web browser, it return OK.
    https://ibb.co/S6TD8wV
    Pls advice and thank you.
    in reply to: Try Notification plugin #15897
    kcks66
    Hi Mikhail,
    I managed to change Notification panel width now.
    in reply to: Try Notification plugin #15835
    kcks66
    Hi Mikhail,
    I managed to find the notification css file and changed from 30% to 10%. I downloaded configuration and uploaded configuration.
    https://ibb.co/X3xnbdB
    However, nothing changed as the notification panel remain 30%.
    I use developer tool to change 30% to 10% it worked.
    https://ibb.co/71qSfK5
    https://ibb.co/5kg1RXJ
    However, the notification changed back to 30% after I refresh web browser.
    Pls advice for how should I change the notification width the correct way?
    • This reply was modified 1 year, 10 months ago by kcks66.
    in reply to: Try Notification plugin #15832
    kcks66
    Hi Mikhail,
    Noted for the event acknowledgement should be PlgMain. By the way, where shall I look for the CSS files?
    in reply to: Connection state is Error #15656
    kcks66
    Hi Mikhail,
    Looks like I shall check Rapid SCADA status whenever Windows update is taken place.
    in reply to: Connection state is Error #15650
    kcks66
    I can see from Server log Communicator kept log-in and disconnected through out these few days:
    2024-11-23 13:40:06 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-23 13:40:36 [MEMC][MEMC$][ACT] Delete outdated data from the Min archive older than 26/11/2014
    2024-11-23 13:40:36 [MEMC][MEMC$][ACT] Delete outdated data from the Hour archive older than 26/11/2014
    2024-11-23 13:43:54 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-23 13:45:01 [MEMC][MEMC$][ACT] Session with ID 4066578528122088325 created
    2024-11-23 13:45:01 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-23 13:45:01 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-23 15:36:47 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-24 02:13:27 [MEMC][MEMC$][ACT] Session with ID 87564178681405224 created
    2024-11-24 02:13:27 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-24 02:13:27 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-24 03:15:47 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-24 03:16:57 [MEMC][MEMC$][ACT] Session with ID -3227744418381615762 created
    2024-11-24 03:16:57 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-24 03:16:57 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-24 03:19:52 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-24 03:21:51 [MEMC][MEMC$][ACT] Session with ID 8234002177814312848 created
    2024-11-24 03:21:51 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-24 03:21:51 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-24 03:31:28 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-24 04:41:27 [MEMC][MEMC$][ACT] Session with ID 2911557974464289601 created
    2024-11-24 04:41:27 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-24 04:41:28 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-24 10:40:00 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-24 10:59:25 [MEMC][MEMC$][ACT] Session with ID -5129900506855778040 created
    2024-11-24 10:59:25 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-24 10:59:25 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-24 20:35:59 [MEMC][MEMC$][ACT] Delete outdated data from the Min archive older than 27/11/2014
    2024-11-24 20:35:59 [MEMC][MEMC$][ACT] Delete outdated data from the Hour archive older than 27/11/2014
    2024-11-24 20:35:59 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-24 20:36:02 [MEMC][MEMC$][ACT] Session with ID 7426910769959558500 created
    2024-11-24 20:36:02 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-24 20:36:02 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-24 20:56:05 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-24 20:56:35 [MEMC][MEMC$][ACT] Session with ID -4313990495017375050 created
    2024-11-24 20:56:35 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-24 20:56:35 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-25 06:32:50 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-25 06:33:20 [MEMC][MEMC$][ACT] Session with ID 3605140054192168160 created
    2024-11-25 06:33:20 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-25 06:33:20 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-25 11:26:44 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-25 11:51:35 [MEMC][MEMC$][ACT] Session with ID 7484977101917070139 created
    2024-11-25 11:51:35 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-25 11:51:35 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-25 22:40:00 [MEMC][MEMC$][ACT] Delete outdated data from the Min archive older than 28/11/2014
    2024-11-25 22:40:00 [MEMC][MEMC$][ACT] Delete outdated data from the Hour archive older than 28/11/2014
    2024-11-25 23:27:31 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-25 23:28:00 [MEMC][MEMC$][ACT] Session with ID 6198346968984755963 created
    2024-11-25 23:28:00 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-25 23:28:01 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-26 08:53:39 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-26 08:53:45 [MEMC][MEMC$][ACT] Session with ID -2381103704843185779 created
    2024-11-26 08:53:45 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-26 08:53:45 [MEMC][MEMC$][ACT] User ScadaComm is successfully authenticated
    2024-11-26 08:53:46 [MEMC][MEMC$][ACT] Session with ID 7860151789968894349 created
    2024-11-26 08:53:46 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-26 08:53:46 [MEMC][MEMC$][ACT] User ScadaWeb is successfully authenticated
    2024-11-26 08:53:49 [MEMC][MEMC$][ACT] Client 127.0.0.1 disconnected
    2024-11-26 08:53:50 [MEMC][MEMC$][ACT] Session with ID -1302092992591187326 created
    2024-11-26 08:53:50 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-26 08:53:50 [MEMC][MEMC$][ACT] User ScadaWeb is successfully authenticated
    2024-11-26 08:54:01 [MEMC][MEMC$][ACT] Session with ID 7512486213043968519 created
    2024-11-26 08:54:01 [MEMC][MEMC$][ACT] Client 127.0.0.1 connected
    2024-11-26 08:54:01 [MEMC][MEMC$][ACT] User ScadaWeb is successfully authenticated
    2024-11-26 08:54:52 [MEMC][MEMC$][ACT] Stop listener
    2024-11-26 08:54:52 [MEMC][MEMC$][ACT] Listener is stopped
    in reply to: Default start page after login #15593
    kcks66
    Hi Mikhail,
    This one worked.
    /View/1
    in reply to: Error when download report #15588
    kcks66
    Hi Mikhail,
    That’s great. I managed to download the report. The report size is 181MB.
    I changed the Timeout to 20000.
    in reply to: Error when download report #15582
    kcks66
    Hi Mikhail,
    I have 30 channels and download report with one minute interval for one month period, thus:
    data points = 60 (minutes) X 24 (hours) X 31 (days)
    = 44,640
    Should I 44,640 X 30 (channels)?
    Unfortunately I don’t have setup that can repeat the report dowloading with the same data points in *dat achieve.
    • This reply was modified 1 year, 11 months ago by kcks66.
    in reply to: Error when download report #15571
    kcks66
    Hi Mikhail,
    Error detail as below.
    2024-11-04 15:47:55 [WIN-HHIJ7MIVESP][WIN-HHIJ7MIVESP$][ERR] Unhandled exception:
    Scada.ScadaException: Error building model of section Section1
    —> System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond..
    —> System.Net.Sockets.SocketException (10060): A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
    at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 count)
    at Scada.Client.ClientBase.ReceiveResponse(DataPacket request)
    at Scada.Client.ScadaClient.GetTrends(Int32 archiveBit, TimeRange timeRange, Int32[] cnlNums)
    at Scada.Web.Plugins.PlgElasticReport.Builder.ModelBuilder.TimeDataSectionBuilder.Build(TimeDataSectionConfig sectionConfig)
    at Scada.Web.Plugins.PlgElasticReport.Builder.ModelBuilder.DocumentBuilder.Build(ReportConfig reportConfig, ElasticReportArgs reportArgs, BuilderOptions builderOptions)
    at Scada.Web.Plugins.PlgElasticReport.Builder.ElasticReportBuilder.Generate(ElasticReportArgs args, Stream outStream)
    at Scada.Web.Plugins.PlgElasticReport.Controllers.PrintController.PrintReport1(Int32 reportID, DateTime startTime, DateTime endTime, String archive, OutputFormat format, IntRange cnlNums)
    at lambda_method215(Closure, Object, Object[])
    at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.SyncActionResultExecutor.Execute(ActionContext actionContext, IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeActionMethodAsync()
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeNextActionFilterAsync()
    — End of stack trace from previous location —
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeNextResourceFilter>g__Awaited|25_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ResourceExecutedContextSealed context)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.InvokeFilterPipelineAsync()
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
    at Microsoft.AspNetCore.Session.SessionMiddleware.Invoke(HttpContext context)
    at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
    at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
    at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddlewareImpl.<Invoke>g__Awaited|10_0(ExceptionHandlerMiddlewareImpl middleware, HttpContext context, Task task)
    in reply to: Enter date and time from web browser #15535
    kcks66
    Hi manjey73,
    Got it to enter desired datetime from web browser now.
    in reply to: Understand how event record works #15119
    kcks66
    Hi Mikhail,
    Pls advice for what specific channel value needed to be insert here since I want to copy value from other channel.
    I tried to use command trigger but the result was same like data trigger.
