kcks66
ParticipantHi Mikhail,
Am I advised to upgrade Rapid SCADA to latest version?
kcks66
Noted with thx. I will send you an email about my instance licenses.
kcks66
ParticipantHi manjey73 & Mikhail,
I got the file from coping from the latest Rapid SCADA 6.4.3 installation package.
Thank you.kcks66
ParticipantHi manjey73,
Pls advice for which package you referred to?
I don’t see the PlgMimic.xml in Mimics_2025.09.18.
Thank you.kcks66
Yup, rolling average worked in input channel only.
kcks66
ParticipantNoted with thx.
kcks66
Noted.
kcks66
After I change culture to en-GB, no errors at log and excel file (Historical Data Report & Elastic Report) when I opened them.
Everything look fine except Auto Report Module automatically export the Event Report even I didn’t activate it.
kcks66
I tried with Elactic Report; the result is the same; showing the first 8 characters only.
kcks66
I plan to download all the channels with full text with timestamp into excel for further state change analysis.
kcks66
I tried download the channel from Historical Data Report, but the result is the same; showing the first 8 characters only.
Elastic report can configure to show full text?
Pls advice and thank you.kcks66
Thanks for your advice. Now I able to show full text.
However, I try to trend the text and download to excel, the text were still truncated, cannot show in full text with ChartPro. My full text is “Manual Mode”.
https://ibb.co/nM6X4cN5
https://ibb.co/1JtC2bZZ
https://ibb.co/d0pkQkbVPls advice for correct steps and thank you.
This reply was modified 1 year, 4 months ago by
kcks66.
kcks66
ParticipantTesting Script:
public string CheckModeSelectText()
return “abcdefghijklmnop”;
}kcks66
Thanks for your explanations.
kcks66
I want to ask what is the function of Pull to period as below:
I want to ask what is the function of Use in-memory cache with cache size ratio as below:
