epoch79
Participantthank yo for the mail.
its solved the problems.
one more question is there any expire date for this scadadiag.ddl ?epoch79
Participantsorry its not in 4.5.1 release. i look at the same zip file.
Ok. Where can i get this dll again ?epoch79
Participantwhere can i get that.
you released 4.5.1 a little while ago.
I looked at the ScadaDiag.dll file its same 11.09.2015 23:15 26.112 kbepoch79
Participant11.09.2015
26 kbepoch79
ParticipantI download from this adres but stil same error
http://rapidscada.org/download/scada_4.5_update.zipepoch79
ParticipantI updated today.
epoch79
ParticipantUygulama Hatası: Belirtilen atama geçerli değil.
konum: Scada.Web.Diag.WFrmDiag.Page_Load(Object sender, EventArgs e)
konum: System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Page: http://localhost/Scada/diag/Diag.aspx?viewSet=0&view=4&year=2015&month=9&day=18&cnlNum=101ScadaWeb Log
epoch79
ParticipantHi Mikhail,
Did yo send the module. I cant see in my mail.
If don can you send now ?
thanks..epoch79
Participantok. Can you send me the module for 4.5 to epoch79@gmail.com.
thanks..epoch79
ParticipantI know the module is not free.
I asked 4.5 version for whole solutions changes on github?
I ‘m using 4.4 source code for development and changed somethings in solutions. First of all I need to get whole 4.5 solutions changes and compare mine. Then I want to buy 4.5 control module if possible…epoch79
Participantthank you mikhail, I have done it.
when did you release 4.5 ? and i couldn’t see the source code on githup.For the control module;
You need the machine code. if i want to run this module in another machine every time we pay you 20 dollars?
Or if we want the source code whats gonna cost us ?And on every scada server updates are going to send us updated module dll ?
epoch79
ParticipantI download it. How can i define this rules any idea?
if can do that i want to buy this module.
thanks..epoch79
Participanti write the function above “/*TODO*/” and its complied 🙂
epoch79
There is a problem with the calcengine.cs class.
I added a function to this class named ToS32().
public double ToS32(double x)
if (x < ((256 * 256 * 256 * 256) / 2)) return x;
else
return ((256 * 256 * 256 * 256) – x) * -1;
Also add a formula to channel in administrator like below
ToS32(((256 * 256 * Val(460)) + Val(461)) * 0.001)
I copied the updated calcengine.cs to C:\SCADA\ScadaServer\Log director and restart the scada server but I’m gettin an error like this.
Error compiling the source code of the formulas:
Line 476, column 57: error CS0103: ‘ToS32’ The name ‘identifier’ does not exist in the current contextany opinion ?
epoch79
ParticipantHi
I send the project to info@rapidscada.org.
I solved the formula issue in the scadascheme. What is the cnldata.stat used for?
And is There any example of formula using “;”. -
