Roland
ParticipantSolved by enabling the dll in the bin folder 🙂
Roland
ParticipantI am using MySQL Server 8.0 with the default relations that you defined here:
http://rapidscada.net/doc/content/latest/en/modules/mod-db-export.htmlI also removed the primary key attribute from the datetime column, to allow more than 1 entries from the same second.
Roland
ParticipantI downloaded and copied there, then restarted my PC.
Now I got the following in ModDBExport.log:
Error connecting to DB PostgreSQL – localhost: Could not load type of field ‘System.Net.Security.SslStream:provider’ (0) due to: Could not resolve type with token 01000030 from typeref (expected class ‘Mono.Security.Interface.MonoTlsProvider’ in assembly ‘Mono.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756’) assembly:Mono.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756 type:Mono.Security.Interface.MonoTlsProvider member:(null)
Roland
ParticipantI am using the scada_5.8.0_mono_en package, that I downloaded from here: https://rapidscada.org/download-all-files/download-rapid-scada/
I am using Ubuntu 19.10
Roland
ParticipantThank for the answers. Please find here the corresponding lines from the ModDBExport.log :
2020-04-02 17:45:13 Start ModDBExport module
2020-04-02 17:45:13 Error initializing data source PostgreSQL – localhost: Could not load type of field ‘Npgsql.NpgsqlConnection:CertificateSelectionCallback’ (9) due to: Could not resolve type with token 01000058 from typeref (expected class ‘Mono.Security.Protocol.Tls.CertificateSelectionCallback’ in assembly ‘Mono.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756’) assembly:Mono.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756 type:Mono.Security.Protocol.Tls.CertificateSelectionCallback member:(null) -
