sanan
ParticipantThank you very much for your valuable support.
sanan
ParticipantTry stop-start MQTT Server. It’s reconnected !
.2020-01-13 21:46:26 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Receive packet
100,5178092020-01-13 21:46:27 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Send packet2020-01-13 21:46:28 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Receive packet2020-01-13 21:46:29 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Receive packet
Error: StriderMqtt.MqttProtocolException: Could not read remaining length
at StriderMqtt.PacketReader.ReadRemainingLength(Stream stream)
at StriderMqtt.PacketReader..ctor(Stream stream)
at StriderMqtt.BaseTransport.Read()
at Scada.Comm.Devices.KpMqttLogic.ReceivePacket()
Send packet
Disconnect from MQTT broker2020-01-13 21:46:30 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Error reconnecting2020-01-13 21:46:52 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Error reconnecting2020-01-13 21:47:14 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Error reconnecting2020-01-13 21:47:37 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Error reconnecting2020-01-13 21:47:59 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Error reconnecting2020-01-13 21:48:09 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Error reconnecting2020-01-13 21:48:11 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Send packet
Send packet
Connection established
Send packet2020-01-13 21:48:14 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Receive packet2020-01-13 21:48:15 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Receive packet2020-01-13 21:48:16 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Send packet2020-01-13 21:48:17 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Receive packet2020-01-13 21:48:18 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
sanan
ParticipantAfter replace KpMqtt.dll then look like it reconnect !
2020-01-13 21:32:29 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Error reconnecting2020-01-13 21:32:32 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Error reconnecting2020-01-13 21:32:35 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Error reconnecting2020-01-13 21:32:37 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Error reconnecting2020-01-13 21:32:40 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Error reconnecting2020-01-13 21:32:42 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Send packet
Send packet
Send packet2020-01-13 21:32:44 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Receive packet2020-01-13 21:32:45 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Receive packet2020-01-13 21:32:46 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Send packet2020-01-13 21:32:47 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Receive packet2020-01-13 21:32:49 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
Send packetsanan
ParticipantHi
Thank you so much. My error.
2020-01-13 21:17:33 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
2020-01-13 21:17:33 Error communicating with Device 42 “MQTT Test”: Could not read remaining length2020-01-13 21:17:33 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
2020-01-13 21:17:33 Error communicating with Device 42 “MQTT Test”: Could not read remaining length2020-01-13 21:17:34 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
2020-01-13 21:17:34 Error communicating with Device 42 “MQTT Test”: Could not read remaining length2020-01-13 21:17:34 Communication session with the Device 42 “MQTT Test”, type: KpMqtt
2020-01-13 21:17:34 Error communicating with Device 42 “MQTT Test”: Could not read remaining length -
