ALnaluk
Participanti try it on this formula “Stat() > 0 ? 1 : 0” but it is not my request.
https://www.picz.in.th/image/1-po5-87h8zhrgwqpeoafxma.QBKOOQ
ALnaluk
Participanti want check the status that without input.do you have examples
if(device = connect){
print = on
else
print = off-
This reply was modified 6 years, 7 months ago by
ALnaluk.
ALnaluk
Participantwhat is Stat function?
https://www.img.in.th/image/T14fpEALnaluk
ParticipantALnaluk
ParticipantThank you
ALnaluk
Participanti can do it.thank you for support
ALnaluk
Participantnow i can use mqtt-spy connected.help me use rapid scada connect
ALnaluk
Participantwhen i use node-red connect cloud mqtt can connected but when i use mqtt-spy doesn’t connect to cloud mqtt
This link video
ALnaluk
ParticipantError log
https://www.234.in.th/image/0XBMe
And this xml config
<DevTemplate><MqttParams Hostname=”tailor.cloudmqtt.com” ClientID=”” Port=”15043″ UserName=”pscmbdmc” Password=”pscmbdmc”/>
<RapSrvCnf ServerHost=”127.0.0.1″ ServerPort=”10000″ ServerUser=”ScadaComm” ServerPwd=”12345″/>
<MqttSubTopics>
<Topic TopicName=”/mesparam1″ QosLevel=”0″ NumCnl=”600″/>
</MqttSubTopics>
<MqttPubTopics></MqttPubTopics>
<MqttSubCmds></MqttSubCmds>
<MqttSubJSs></MqttSubJSs>
</DevTemplate>
This reply was modified 6 years, 10 months ago by
ALnaluk.
ALnaluk
Participantwhen i use “KpMqtt:v5.0.0
@2mik 2mik released this on 11 Sep ยท 10 commits to master since this release
KpMqtt: rename KpMqttConfig1”i have this error “Error getting device interface type from the library KpMqtt.dll: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.”
ALnaluk
Participanthttp://picture.in.th/id/a0105e8add43cb7d51965ee19b630112
please help me
