kirjono mudiarto
Participantit solved now, i recreate the default web site in IIS
kirjono mudiarto
Participantmy OS is windows 10
kirjono mudiarto
ParticipantI did not find the OPC server software, it looks like the manufacturer no longer supports it. What about the other option as you said creating native drivers?
kirjono mudiarto
ParticipantCould you guide me step by step how to implement this OPC Server, and also i want to integrate with other devices like PLC, meter, MV Switchgear?
kirjono mudiarto
ParticipantThanks Mikhail, I will start a new topic
kirjono mudiarto
I seem to have the same problem.
I have several devices communicating using Modbus protocol and I have sucessfully communicated with them except for one that communicates with the Remote Procedure Call (RPC) protocol and it said that the data format is JSON.
How can I communicate with RPC through rapidscada?Thanks
kirjono-
This reply was modified 6 years, 10 months ago by
kirjono mudiarto.
kirjono mudiarto
ParticipantThank you very much Mikhail
kirjono mudiarto
ParticipantHi Mikhail,
thank you for the replies, now it works.
I have changed the address to 30006-30007.
I’ve realized that the address must be added by 1 since rapidscada address starting from 1 and device address starting from 0.kirjono mudiarto
Participant2019-12-20 08:04:18 Communication session with the Device 1 “Test device”, type: KpModbus, address: 1, call number: 192.168.0.152
Request element group “gateway”
Error writing data: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
Receive (0/7):
Communication error!
Unable to request because connection is not established
Unable to request because connection is not established2019-12-20 08:04:20 Establish a TCP connection with 192.168.0.152:502
2019-12-20 08:04:20 Communication session with the Device 1 “Test device”, type: KpModbus, address: 1, call number: 192.168.0.152
Send (12): 00 00 00 00 00 06 01 04 75 34 00 02
Receive (7/7): 00 00 00 00 00 03 01
Receive (2/2): 84 04
Device error: [04] SLAVE DEVICE FAILURE!
Device error: [04] SLAVE DEVICE FAILURE!2019-12-20 08:04:21 Disconnect from 192.168.0.152
kirjono mudiarto
https://ibb.co/ZMcGyz8
https://ibb.co/cC5DD88
https://ibb.co/H218Bqm
https://ibb.co/mG7RRJ8
https://ibb.co/T2DMmS5-
This reply was modified 6 years, 11 months ago by
kirjono mudiarto.
kirjono mudiarto.
kirjono mudiarto.
kirjono mudiarto.
