greenfoxx
Viewing 15 posts - 1 through 15 (of 23 total)
  • in reply to: Grafana Integration on RapidScada 6 #13165
    greenfoxx
    Hi!
    We faced that Grafana plugins, such as grafana-simple-json-datasource, become obsolete too often and unpredictable.
    We decided not too use special plugins to integrate Rapid SCADA and Grafana. With Rapid SCADA 6.x you should configure archives to store historical data into database, then display data by Grafana. I suggest storing historical data to PostgreSQL.
    Could you please check short instructions for working with Grafana
    PostgreSQL data source and Rapid SCADA.
    Work at Grafana:
    1. Choose as data source PostgreSQL.
    2. Set the data source’s basic configuration options in setting tab.
    For example:
    Host: The IP address/hostname your PostgreSQL instance
    Database: rapid_scada
    User: postgres
    Password: Database user’s postgres password – postgres
    3. Write a sql-query. You can use Query builder or Query editor.
    4. Simple query example (Query on one channel, not including into stat = 0, and also not showing a gap, if there is no data in a certain period of time)
    SELECT
    time_stamp AS "time",
    val
    FROM mod_arc_postgre_sql.mincopy_historical
    WHERE
    cnl_num = 101
    ORDER BY 1
    in reply to: MQTT Issue #8716
    greenfoxx
    From this link you can find Mqtt – Spy https://github.com/eclipse/paho.mqtt-spy
    in reply to: MQTT Issue #8715
    greenfoxx
    Hi Kokoi!
    What broker do you use in your example? Have you tried to connect to server broker using MQTT Spy for example?
    in reply to: Access Rapid SCADA data from Node-RED #7392
    greenfoxx
    Yes, we fixed.
    Please check.
    in reply to: Access Rapid SCADA data from Node-RED #7371
    greenfoxx
    Thank you very much Kumajaya! We accepted your changes in the last commit. You were right.
    The issue has been fixed.
    in reply to: Access Rapid SCADA data from Node-RED #7356
    greenfoxx
    We fixed this issue.
    in reply to: MQTT at Linux/Ubuntu #7313
    greenfoxx
    Hi!
    Could you please download the new dll which you can find here https://yadi.sk/d/KlvaH845L42KyQ
    Has been added to the log file detailed information about the error.
    in reply to: Access Rapid SCADA data from Node-RED #7288
    greenfoxx
    Thank you for details. We’ll investigate the problem and issue a fix. Thanks for the report.
    in reply to: Access Rapid SCADA data from Node-RED #7281
    greenfoxx
    Could you please provide response from Grafana? It’s help me.
    in reply to: Access Rapid SCADA data from Node-RED #7275
    greenfoxx
    Grafana Data Provider API represents parameters transmitted to Grafana for build graph and converts the specified date and time to the unix milliseconds.
    • This reply was modified 6 years, 2 months ago by greenfoxx.
    in reply to: Access Rapid SCADA data from Node-RED #7264
    greenfoxx
    Hi!
    Could you please clarify your question?
    in reply to: Grafana setting #6751
    greenfoxx
    Hi Trauden!
    Thank you for your message.
    Could you please set parameter allow_embedding = true in file defaults.ini wich you can find C:\Program Files\GrafanaLabs\grafana\conf
    and restart.
    More information https://github.com/grafana/grafana/issues/17458
    I will add this important information in file ReadMe.MD
    • This reply was modified 6 years, 7 months ago by greenfoxx.
    in reply to: Realtime DB access and indication #6681
    greenfoxx
    Could you provide versions ScadaServer, ModDBExport and PostgresSQL?
    in reply to: Restat comminuacation line by command #6398
    greenfoxx
    Hi!
    Probably, you can see the error ‘Could not read remaining length’.
    The exception occurs when there is no data to read or the connection is no longer valid.
    You can test the following update https://yadi.sk/d/HPI_FkFPfrXbhA
    in reply to: MQTT in-depth Installation Help #6268
    greenfoxx
    UPD to ALnaluk:
    try to Upload Configuration again
