dsantiago
ParticipantMikhail
It is not doing this automatically how to we make sure they can communicate???
Thank you,
Dawndsantiago
ParticipantMikhail:
ALL of the machines are VMs. Do you mean the main VM with all software installed?
Thank you,
Dawndsantiago
ParticipantMikhail:
How do I connect the 1st VM and the 2nd VM to the communicator. We installed 5.6 on 1st computer, 2nd computer we have communicator and agent.
Thank you,
Dawndsantiago
ParticipantMikhail:
When you say agent you mean the modbus and OPC, is this correct.
Thank you,
Dawn Silvermandsantiago
ParticipantMikhail:
I forgot to ask you about a key that would be needed to use the Rapid Gate. How would this be obtained?
Thank you,
Dawndsantiago
ParticipantHi Mikhail:
These would simulated devices in a vm on different vm computers. The Modbus RTU and OPC connected device would be used.
Main SCADA______RTU______Device
______RTU______DeviceBoth RTU machines would be attached to the main SCADA. I was reading up and it looks like we can use the Rapid Gate to communicate between computers. However, I am not clear if a full version of SCADA software would have to be installed on all VM machines.
Thank you,
Dawn -
