Hi Mikhail,
My main requirement is , i want use Rapid scada as listener same as (TCP/IP socket listener) , but with MQTT protocol, so that my GSM module from different location connects to MQTT broker of Rapid scada and push the data to it. The communicator collects data from MQTT broker and store in database.At present the communicator is polling by RS485 modbus and TCP/IP modbus i want communicator as listener in TCP.
This reply was modified 7 years, 7 months ago by
Akhila.
