camtutrinhha
ParticipantI’m sorry.
I have a file data in Microsoft SQL Server
https://drive.google.com/open?id=1bYp5CqtpbDAZR9oOSzCkWxpwlC8eMmxf
in Scada Server, I have a file .dat
https://drive.google.com/open?id=1U3kXKCm8x28is1WjILFYkwhNMHKnQlF8
But, Date_Time in Microsoft SQL unlike Date_Time in Scada Server.
Therefore, I want to read Date_Time in Microsoft SQL and write it in ScadaServer.
Example,
https://drive.google.com/open?id=15GCw51hQStNQ-WkGFt0iEe5QM53i9kyD
Notice Time, please.
Could you tell me how to resolve it?
Thanks-
This reply was modified 7 years, 7 months ago by
camtutrinhha
ParticipantThanks,
I resolved it.
Now, i’m having a problem.
I have data like below image
curently I read only data in multiple days serial but it run follow real time of my computer ,
https://drive.google.com/open?id=1jyXuNpgXJNqgb5HbJZHRfJ77BsEEkw7u
I desire that i can read data in multiple days and create multiple file extensive .dat in a day. To have data quickly.
Thank you!-
camtutrinhha
The browser has affected webstation application, hasn’t it?
Thanks!camtutrinhha
ParticipantThank you!
example, I want to read data from available .xlxs file instead of reading directly from Modbus TCP. In order to display on webstation. can you show me how to resolve it?
Regards,camtutrinhha
Could you tell me how to perform publish in VS 2017?
Thank you!camtutrinhha
After successfully building, Could you tell me how to pack RapidScada?
Thankscamtutrinhha
I’m sorry about my English.
Can you show me how to pack ScadaWeb?
Thanks in advance!camtutrinhha
This below image which describes position of set up ScadaWeb.
is it right there?
Error
Thanks!camtutrinhha
i installed successful Rapid SCADA from distributive,
then i packaged it ScadaAdmin, ScadaComCtrl, ScadaSeverCtrl, ScadaScheme, ScadaTableEditor, ScadaWeb. It operated usual until i access webstation and it didn’t as my desire.
I think set up project of ScadaWeb incorrect.
Example, set up project of ScadaAdmin in ScadaAdmin project,..
but set up project of ScadaWeb in ScadaWebShell5? wonder if it correct
Regards,-
This reply was modified 7 years, 8 months ago by
camtutrinhha.
camtutrinhha
it notifies error which “cannot find the file ScadaData.en-GB.xml in C:\ScadaWeb\lang”, i tried to add it and rebuilt, then i fixed it.
but Interface wasn’t as my desired.
This below images which describes my interface.
errorThanks in advance!
camtutrinhha.
camtutrinhha
I deleted all the files with the .min.css extension, then I added it again and recompiled.
So successful,camtutrinhha
Participanthello,
i fixed to my error
thank you very much,camtutrinhha
Participanthi,
this is image which describes my error
errorwhen i built ScadaWeb, it notifies error that the system cannot find the file specified as splitter.min.css while i have it in my drive.
Thanks in advance!
camtutrinhha.
camtutrinhha
Participanthi,
i have a error similar #5010 when i built ScadaWeb.
Would you tell me how to resolve with it?Thanks,
