scadarapid
ParticipantNormally, We use register from ModbusRTU to relate with input channel and output channel. If I do not have any register from ModbusRTU but I need to relate the value from Scada-Administration input channel and output channel.
How can I do.Example I create an input channel number 1000 then, I want it to receive value from button on Web-station when I do not click the button the value of input channel = 0, if I click it the value input channel = 1, after that I will use this value of input channel to make relation something. It likes input enable button.
I apologize,if my explanation is not good.
Thank you so much.
scadarapid
ParticipantHi, Mikhail
Can I make an toggle scheme to send data only 0 or 1 to the input channel,
If I do not have any register and output channel.the input channel direct receive the value from toggle scheme. than I will use that value from input channel to make relations to another input channel.
scadarapid
ParticipantHi.
I forgot to change configuration Web Application at Chart Plugin so, I change it from Chart to Chart Pro.
It already work.Thank you so much.
scadarapid
ParticipantI have send my Computer Code and my email to Admin already.
on 2019/03/28 Time 9:00 AMThank you so much
