scadarapid
ParticipantHow can I get the computer the key in Raspberry Pi.
Now, I already finish to setup in PC and automatic control work perfectly on PC then, I transfer all file to Rpi everything works fine except the Automatic control module
the problem that i have found, I did not find computer code on Rpi to send to you to get trial key. how can I solve this problem. Please suggest.
thank you so much.
scadarapid
ParticipantIn your case you need a license only for RPi.
How can I buy automatic control module for RPi cause i did not see this plugin on your site.
scadarapid
ParticipantHi, I have questions about Raspberry Pi and Automatic Control Module.
1.How can we buy Automatic Control Module and set up in the Raspberry Pi?
2.Do we have to set up in the Computer PC with Automatic control Module before we transfer data to Raspberry Pi, Do we have to buy Automatic control Module in computer and in Raspberry Pi?.Thank You so much.
scadarapid
ParticipantWhen I can not send the command to my output the server will be error, I have to restart the server, then the server will comeback.
scadarapid
ParticipantScadaServer.log
ived from the client 127.0.0.1
2019-04-24 15:14:57 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:14:58 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:14:58 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:14:58 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:14:58 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:14:58 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\BaseDAT\incnl.dat
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the minute data table is completed
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the minute data copy table is completed
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:03 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:03 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:03 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:03 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:03 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:04 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:04 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:04 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\BaseDAT\incnl.dat
2019-04-24 15:15:06 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:06 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:06 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:06 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:06 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:07 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:07 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:07 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:09 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:09 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:09 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:09 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:09 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:11 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:11 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:11 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:11 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:11 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:12 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:12 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:12 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:12 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:12 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\BaseDAT\incnl.dat
2019-04-24 15:15:14 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:14 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:14 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:14 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:14 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:16 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:16 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:16 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:16 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:16 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:18 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:18 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:18 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:19 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:19 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:19 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:19 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:19 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\BaseDAT\incnl.dat
2019-04-24 15:15:21 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:21 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:21 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:21 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:21 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:22 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:22 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:22 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:22 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:22 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:25 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:25 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:25 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:25 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1scadarapid
ParticipantMy ScadaCommSvc.log —> sometime I can send commands to my output, sometime i cannot send command to my output.
From ScadaCommSvc.log
2019-04-24 15:06:30 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:31 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:32 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:32 <DESKTOP-1CTUDRI><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2019-04-24 15:06:37 <DESKTOP-1CTUDRI><SYSTEM><EXC> Error connecting to SCADA-Server: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2019-04-24 15:06:37 <DESKTOP-1CTUDRI><SYSTEM><ACT> Disconnect from SCADA-Server
2019-04-24 15:06:37 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:38 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:39 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:40 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:41 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:42 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:42 <DESKTOP-1CTUDRI><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2019-04-24 15:06:43 <DESKTOP-1CTUDRI><SYSTEM><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2019-04-24 15:06:43 <DESKTOP-1CTUDRI><SYSTEM><ACT> Disconnect from SCADA-Server
2019-04-24 15:06:43 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:44 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:45 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:46 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:47 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:48 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:49 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:50 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:51 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:52 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:52 <DESKTOP-1CTUDRI><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2019-04-24 15:07:24 <DESKTOP-1CTUDRI><SYSTEM><EXC> Error requesting telecommand from SCADA-Server: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.
2019-04-24 15:07:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Disconnect from SCADA-Server
2019-04-24 15:07:25 <DESKTOP-1CTUDRI><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2019-04-24 15:07:26 <DESKTOP-1CTUDRI><SYSTEM><EXC> Error requesting telecommand from SCADA-Server: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.
2019-04-24 15:07:26 <DESKTOP-1CTUDRI><SYSTEM><ACT> Disconnect from SCADA-Server
2019-04-24 15:07:26 <DESKTOP-1CTUDRI><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=1
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=2
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=3
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=4
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=5
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=6
2019-04-24 15:08:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=7
2019-04-24 15:08:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=8scadarapid
Participantthe problem.
i use automatic control to send data to my input channel that I has extra create.
when automatic control send data to my extra input channel. the server will be error.from the picture input
extra Input channels number 9009-9016 my enable input channel that receives data from toggle scheme.
extra input channels number 9017-9026 my time zone input channel that receives data from automatic control. the value will change when i set the time at automatic control module such as when 9AM set 1 to output channel number 9017
extra input channels number 9027 – 9034.from the picture output
9009-9016 output channels that receive data from toggle scheme
9017-9026 output channels that receive data from automatic controlthank you so much.
scadarapid
ParticipantAutomatic control
https://www.img.live/image/7UozsE
https://www.img.live/image/7Uo2jK
https://www.img.live/image/7UoHLr
https://www.img.live/image/7Uobut
formula
https://www.img.live/image/7UopeZ
output channel
https://www.img.live/image/7UoXKR
input channel
https://www.img.live/image/7Uoftiscadarapid
ParticipantWhen I send data from Automatic to input channel why it always make error server.
please help
I will send you all information.thank you so much.
scadarapid
ParticipantI already finish this work.
If I would like to buy Automatic Control Module. How are differences between Personal and Business.
Thank you so much.
scadarapid
ParticipantHow can we do this formula.
int a;
if(input1 > 0){
if(input2 > 0){
a = input2;
}else{
a = input3;
return a;scadarapid
ParticipantI expect to make time schedule to my output. when enable button value = 0
my output will follow the switch(on/off), if enable button value = 1, output follow the time schedule on/off.I have 8 outputs then, each output has 2 buttons including with enable button( it receive data from the toggle scheme then, I keep it in input channels Administration ) and time schedule button(I use automatic control to send data in input Channel).
such as if I push the enable button of output number 1, the output number 1 will be on following the timezone(Timeschdule) if timezone number 1(Automatic control will send data to my input channel, I will set time on and time off) is on, the output number 1 will be on(I make AND logic between Enable button and Timeschedule button)
thank you so much.
scadarapid
Participanthttps://www.img.live/image/7UJAPs
https://www.img.live/image/7UJPiR
https://www.img.live/image/7UJI4i
my purpose
If my enable1 is on and TimeZone1 is on, the output1 channel 9001 is on
if my enable is off, TimeZone must be off and led will be follow the command.thnak you so much.
scadarapid
ParticipantHi, Mikhail
Now, I can send data from the toggle scheme to my input channel and I make it 2 channels. then I make AND logic with input channel 1 and channel 2. after that, I send the data to my output channel 1 but it does not work.
how can i do, 2 input channels with 1 output channel. it show data “on” but it dose not send the command to the output device.
scadarapid
ParticipantThank you so much
