eurusyangParticipantThankes,I have changed the size.
eurusyangParticipantI use rapid scada in oil transmission system,there are so many data need send to scada server.I hope you can change the size.I do some change in your code to send data to server.
eurusyangParticipantDear Mikhail,
as we all know,65535 bytes are not a lot,I need send tens of thousands of bytes to ScadaServer.I hope you can change the limit.
My computer has 16G memory…When debug ScadaServer,also very card.
ScadaComm runs 3 hours,ScadaComm Services is already used900M memory in task Manager.
You are very nice and can respond to my news in time.
eurusyangParticipantsorry,i do not understand,why do this process.why not send data directly.dear Makihal
eurusyangParticipantI want to debug ScadaComm, In VS goto Debug -> Attach To Process and find ScadaCommSvc.exe.but i can’t debug.i don’t know why?plwase tell me .
eurusyangParticipantthanks first ,I need some time to read,if I have problem,i will ask you.
eurusyangParticipantand i want to know where to find scada_5.x.x_full_en.zip?Thanks a lot.
eurusyangParticipantI think high Bit and low Bit?But why?Can you explain detailed?
eurusyangParticipantHi,
I do as you say,but the result is failed. I still can’t find the ScadaServerSvc.exe,only find ScadaServerCtrl.exe.I attach the ScadaServerCtrl.exe,but failed to debug.I feel very sad.
eurusyangParticipantthank you very much . I am a college student.My Russian is very poor.
eurusyangParticipantThanks,can i install .Net Framework in win XP?
