Krzysztof
ParticipantKrzysztof
ParticipantFormula
Chanel config
Server message
Calc log
Krzysztof
ParticipantFormula
https://drive.google.com/open?id=1zUaBomMFXQrcGidyvxGruY4DvjA9rrlL
Chanel config
https://drive.google.com/open?id=13sTrm8towtqriEB8nv77E6FE8-s4ZEFk
Server message
https://drive.google.com/open?id=1ZXHOlk5K3gM7Qg_QF5U-w5ywZ8oSM5ci
Calc log
https://drive.google.com/open?id=1w7Um7WaWi5-J5Ep8jp_V76htfDlDiuI--
This reply was modified 6 years, 8 months ago by
Krzysztof.
Krzysztof
Participanthmm, I don’t see my replay
Krzysztof
ParticipantI restart the server and send the configuration very often, because I work a lot on this Rapid Scada instance. Status before alarm 13, after 15. At the moment I can tell that it does not work only with calc real. Earlier I tried to refer to val (7239), but it did not work well, so I moved to a reference to status and in this case it does not work at all. I will experiment on a test instance and we will see that I can determine. Meanwhile, I’m putting my module config. Maybe I demand too much of him.
Krzysztof
ParticipantEverything is in this screen
Krzysztof
Participantthx guys
Krzysztof
ParticipantHello
Second problem
I have cnl_1 as calculated real that uses high and high alarm thresholds, status 14 and 15.
In Automatic Module I set triger if status cn_1 is 14 or 15 send comand 1.
The event comes, but the command is not executed, there is nothing in the log.
Any ideas ?Krzysztof
ParticipantHelo
I have a problem with communication with the slave simulator.
I can’t ask him for more than 127 registers. It does not appear to have such a limitation. Is there any restriction on Rapid Scada or modbus driver?Krzysztof
ParticipantExample
Chanel 1 number 1011
Chanel 2 number 1012
Chanel 3 number 1013
Create Chanel 4 with number 1014 or other and enter the formula:
(Val (1011) + Val (1012) + Val (1013)) / 3 -
