Hennie_Kotze
Viewing 7 posts - 31 through 37 (of 37 total)
  • in reply to: localhost/scada/ #4610
    Hennie_Kotze
    Windows 10 professional…
    Should i be able to see localhost as a service?
    in reply to: localhost/scada/ #4609
    Hennie_Kotze
    Yes, that is correct. If i try to open http://localhost, it says the site cant be reached.
    I did un-install the software and restarted my PC. I installed the software again, and restarted the PC. I did this twice.
    In my previous message i included my install log file that indicates the software installed correctly.
    The Re-install does not work.
    I am using Windows 10
    in reply to: localhost/scada/ #4605
    Hennie_Kotze
    I also have a problem with my Localhost…
    Explorer says: “This site cant be reached”.
    I followed the “turn windows features on or off” exactly like its indicated, but it still does not work.
    I checked the default pool is .NET V4.0 and an integrated pipeline mode.
    I made sure no other processes are using port 80.
    I can successfully connect with my device, and even send commands, but my webstation does not start up…
    I uninstalled and re-installed the software twice already.
    Here is my install log:
    Start Rapid SCADA 5.5.3 installation 11/16/2018 12:55:30 PM
    Create directory C:\SCADA\
    Create directory C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SCADA\
    Install Server application
    Unzip files from ScadaServer.zip
    Create shortcut Server
    Install service ScadaServerService
    Installation of Server application has completed successfully
    Install Communicator application
    Unzip files from ScadaComm.zip
    Create shortcut Communicator
    Install service ScadaCommService
    Installation of Communicator application has completed successfully
    Check the configuration of Internet Information Services (IIS)
    Go to
    Control Panel > Programs > Turn Windows features on or off
    and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
    whereas the components for .NET Framework 3.5 are switched off
    Check Windows Communication Foundation (WCF)
    Register ASP.NET
    Install Webstation application
    Unzip files from ScadaWeb.zip
    Selected application pool: DefaultAppPool
    Register web application Scada
    Create shortcut Webstation
    Installation of Webstation application has completed successfully
    Check Microsoft SQL Server Compact 3.5
    Unzip files from ScadaAdmin.zip
    Create shortcut Administrator
    Installation of Administrator application has completed successfully
    Install Table Editor application
    Unzip files from ScadaTableEditor.zip
    Create shortcut Table Editor
    Installation of Table Editor application has completed successfully
    Install Scheme Editor application
    in reply to: Siemens Logo! Modbus #4474
    Hennie_Kotze
    Mikhail,
    What recommendations are you referring to?
    MK,
    I will send a compilation of screenshots of all my settings, on the scada and on the PLC. I’m in South Africa (GMT +2) so we are going to bed now. Will send them in the morning.
    From what i can see in your initial question, you are trying to send a command from the scada to the PLC via network input. Now i have used these network inputs and outputs successfully between two PLC’S, but i think you should maybe send your command via memory address (M) in the PLC. In your modbus address screen shot you’ll see they are mapped as coil 8257. They are read / write (RW). So instead of using the NI1, just use coil 8257 and in the PLC that will be M1.
    I will try that tomorrow and let you know.
    From where are you?
    in reply to: Siemens Logo! Modbus #4467
    Hennie_Kotze
    MK,
    Sorry to hear that….
    Did you find an alternative?? I would also like to explore different options…
    I managed to get my communication working, but now i’m struggling with the graphics in the web station…
    HK
    in reply to: Siemens Logo! Modbus #4465
    Hennie_Kotze
    Mkieffer,
    Can you please share some screenshots of your PLC setup (Network project) and settings, as well as your rapid scada settings?
    I’m still struggling to get connection between the two…
    in reply to: Siemens Logo! Modbus #4458
    Hennie_Kotze
    Mkieffer,
    I am working on the same PLC at the moment.
    Did you manage to get your system working?
    Would you mind collaborating with me via email so i can learn how you configured your software please?
    Hennie Kotze
    hennie _aty_ kwenamining.co.za
    +27794914321 (south africa)
    Regards,
    • This reply was modified 8 years ago by Mikhail.
