SuperDev
ParticipantBut i don’t have problem in https. I have configured my linux server and it loads https and converts http to https as well.
The only problem is Url Rewrite. when https loads the schemes (in iframe) doesn’t load.
Exactly like this in windows:
https://forum.rapidscada.org/?topic=run-self-ssl-to-secure-scada/#post-4623SuperDev
ParticipantI did not have problem with https running. The only problem is URL Rewrite like on windows. https://forum.rapidscada.org/?topic=run-self-ssl-to-secure-scada
As you remember we added Url Rewrite on IIS and made it work.
But on linux again that problem occurs when running https and any trick we did we couldn’t solve the problem.
yet the errorScheme loading failed. Try to reload scheme
shows while loading scheme
<img src=”http://s8.picofile.com/file/8344101834/iis0.png” alt=”error loading scheme in rapid scada” /SuperDev
Participantyou’re welcome sir
SuperDev
ParticipantFortunately the problem solved.
The reason wasn’t rapidscada. The iis was causing the problem.
Remember to config URL Rewrite while configing iis and installing ssl.
complete introduction and help is in the link below:
https://www.namecheap.com/support/knowledgebase/article.aspx/9953/38/setting-up-an-httphttps-redirect-in-iisRemember:
after you created a rule for url rewrite, a web.config file will be created in C:\inetpub\wwwroot. go to this path, open the web.config file and remove rewrite section and save and EnjoySuperDev
ParticipantThanks for rapid reply.
yet some problems remain as belows:
1. I replaced all of the web.configs as mentioned in the folders and the below error occured.
2. I replaced only web.config of Scheme. the above problem solved and scheme loading problem solved too. but the below error is shown:
Error updating scheme data
