Muhd Afham
How to create a led condition based on value from different channel. As example, if the value channel 1 is less than value in channel 2, led turn to red. if the value in channel 1 and channel 2 is equal, the led turn to green.It is possible to do it using Rapid Scada?
Muhd Afham
ParticipantOK thanks, it working.
Muhd Afham
I am new to learn this software for my project. Yes i have tried using the hercules utility. But the connection fail.Below is the link for resource monitor if you would like to see the port usage in my pc.
https://ibb.co/jJ4REzscadaserver\log
2018-09-21 02:54:40 <MSI><SYSTEM><ACT> ScadaServerService 5.1.0.3 is started
2018-09-21 02:54:40 <MSI><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2018-09-21 02:54:40 <MSI><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2018-09-21 02:54:40 <MSI><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 100
2018-09-21 02:54:40 <MSI><SYSTEM><ACT> Ouput channels are read from the configuration database
2018-09-21 02:54:40 <MSI><SYSTEM><ACT> Users are read from the configuration database
2018-09-21 02:54:40 <MSI><SYSTEM><ACT> Formulas are read from the configuration database
2018-09-21 02:54:40 <MSI><SYSTEM><ERR> Error compiling the source code of the formulas:
Line 571, column 125: error CS1026: ) expected
Line 574, column 82: error CS1002: ; expected
Line 574, column 82: error CS1525: Invalid expression term ‘)’
Line 577, column 82: error CS1002: ; expected
Line 577, column 82: error CS1525: Invalid expression term ‘)’
2018-09-21 02:54:40 <MSI><SYSTEM><ERR> Normal program execution is impossible.
2018-09-21 02:54:45 <MSI><SYSTEM><ACT> ScadaServerService is stoppedMuhd Afham
ParticipantHi, i am trying to login in (http://localhost/Scada/Login.aspx) but cannot log in. The web show message (services is unavailable). i have try using hercules utility to connect the TCP port and the IP address but the connection is failed.
can you guide me how to solve this problem.
This is the web log.
2018-09-21 03:20:29 <MSI><DefaultAppPool><ACT> Initialize common web application data
2018-09-21 03:20:30 <MSI><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2018-09-21 03:20:31 <MSI><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2018-09-21 03:20:31 <MSI><DefaultAppPool><ACT> Disconnect from SCADA-Server
2018-09-21 03:20:31 <MSI><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
Scada.ScadaException: Unable to receive the configuration database modification time.
at Scada.Client.DataCache.RefreshBaseTables()
2018-09-21 03:20:31 <MSI><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: use4i2uxoisbvsmmkwxh2gmb
2018-09-21 03:20:38 <MSI><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2018-09-21 03:20:38 <MSI><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2018-09-21 03:20:38 <MSI><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: ::1
2018-09-21 03:21:02 <MSI><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2018-09-21 03:21:03 <MSI><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2018-09-21 03:21:03 <MSI><DefaultAppPool><ACT> Disconnect from SCADA-Server
2018-09-21 03:21:03 <MSI><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2018-09-21 03:21:03 <MSI><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2018-09-21 03:21:03 <MSI><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: ::1
2018-09-21 03:21:08 <MSI><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2018-09-21 03:21:08 <MSI><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2018-09-21 03:21:08 <MSI><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: ::1
2018-09-21 10:51:43 <MSI><DefaultAppPool><ACT> User information has been removed. IP address: ::1. Session: use4i2uxoisbvsmmkwxh2gmb
2018-09-21 11:01:32 <MSI><DefaultAppPool><ACT> Application shutdown -
