mariodavid
Viewing 9 posts - 46 through 54 (of 54 total)
  • in reply to: OPC write value issue-IBH opc server #4353
    mariodavid
    the manufacturer wrote: “I would think that installing the OPC Foundation OPC Analyzer as a go-between between Rapdid Scada and the Server would give them all the information that is needed”.
    How can i get the OPC analizer?
    in reply to: OPC write value issue-IBH opc server #4333
    mariodavid
    how the OPC server could be debugged with SCADA-communicator?
    if you need, this this the mail of the manufacturer: mholbach@softwaretoolbox.com
    in reply to: OPC write value issue-IBH opc server #4332
    mariodavid
    Hi, answer of the manufacturer:
    “Hello Mario,
    I am sorry for the delayed response, unfortunately Colin is not in the office. We do not offer a student license for the server, but I would be happy to help identify the issues. What kind of debugging is Rapid Scada wanting us to do? I would think that installing the OPC Foundation OPC Analyzer as a go-between between Rapdid Scada and the Server would give them all the information that is needed.
    What kind of write issues are you seeing? Are you sure it is an issue with Rapid Scada? Or are the points potentially being overwritten controller side/ or are the items read only in the Server?
    Kind Regards,
    Marc”
    in reply to: OPC write value issue-IBH opc server #4328
    mariodavid
    I wrote to the manufacter but not answer yet. I do not not opc ua opction. How can i get the Source code of KpOpc.dll?
    in reply to: OPC write value issue-IBH opc server #4307
    mariodavid
    I am using Matrikon OPC to write Bucket brigade.boolean and Bucket brigade.int1 tags and works well. Also, i tried to write tags with QUICK CLIENT using IBH opc server and works well.
    I tried to restart Communicator service and Server services after 30 minutes and the quality tag still: UncertainLastUsableValue.
    I need to restart the computer to use the server again.
    • This reply was modified 8 years, 1 month ago by mariodavid.
    in reply to: OPC write value issue-IBH opc server #4277
    mariodavid
    I am using a demo version of IBH opc sever. This only lasts connected 30 minutes. Everytime the time is over, I need to restart the computer to use again the server. with QUICK client I just need to close the aplication and re-open it. When I restart the comnunication line in rapid scada the tags quality is: uncertainlastvalue. So i can not use the server until i restart the computer. how can i do?
    in reply to: OPC write value issue-IBH opc server #4275
    mariodavid
    I am using an IBH OPC SERVER to connect to PLC through an MPI/USB siemens adapter. the protocol is S7 Simatic Net. I’ve been trying write tags with OPC QUICK CLIENT and the same thing happens. I will try to sending commands to Matrikon OPC…
    in reply to: OPC write value issue-IBH opc server #4265
    mariodavid
    communication line log:
    “2018-09-12 10:41:02 Command to Device 81 “llenado.diesel”,type: Kopc
    Tag value has been passed to OPC server. Name: PLC1.Generic.sensor-nivel-bajo-tanque-principal
    2018-09-12 10:41:02 Device 81. Handle current data changing. Subscription: llenado.diesel
    Device 81. Process tag. Name: PLC1.Generic.sensor-nivel-bajo-tanque-prinicipal. Value: True. Quality: good
    2018-09-12 10:41:03 Device 81. Handle current data changing. Subscription: llenado.diesel
    Device 81. Process tag. Name: PLC1.Generic.sensor-nivel-bajo-tanque-prinicipal. Value: False. Quality: good”
    in reply to: OPC Write value issue – Matrikon Simulation #4231
    mariodavid
    I’m using an OPC server to connect to a PLC plc s7-300. I did everything that is said above but the value in the “Device Data” tab does not seem to change.
    “2018-09-12 10:41:02 Device 81. Handle current data changing. Subscription: llenado.diesel
    2018-09-12 10:41:02 <CONTROL-PC><SYSTEM><ACT> The command is received from file: type=Standard, device=81, number=4”
    i want set the tag to true but
    immediately changes to false
    how can i do?
