schmidtw
  • in reply to: SQL Export Issues #3296
    schmidtw
    That doesn’t seem to have had a major effect, even after restarting all pertinent services.
    Even with that change, it will write all 20 sensors (even though 10 are active in Administrator), then 10 minutes later it skips writing anything, then 10 minutes later it will write all 0 (impossible), and then 10 minutes later it will write actual values for all 20 sensors again, with the 10 inactive ones as 0.
    in reply to: SQL Export Issues #3283
    schmidtw
    I changed the delay in communicator to only poll at the interval I wanted, but there are more values in SQL being written.
    For example, it will write the value of 20 sensors (even though only 10 are active) at the interval I want fairly consistently, but then it will skip a 10 minute interval, or in between intervals, a few other sensors will generate SQL data, but they are all on the same setting.
    in reply to: SQL Export Issues #3220
    schmidtw
    If you have to control timing with SQL scripts, what’s the point of their being timing options in the file save parameters of the SCADAServer module? Are those specifically for local data?
