nick1365
  • in reply to: Modbus TCP/IP Send different function codes #3156
    nick1365
    I do not need my own function codes, but I just need to make a scenario that uses different function codes (except of function code 1 and 3 that Max,Min avg temperature has). I need to construct some demo procedures that use function code 2,4,5,6,15 and 16 or just send some function codes manually (I know the sequence of function codes that one specific procedure has).
    in reply to: Modbus TCP/IP Send different function codes #3154
    nick1365
    Thank you for your prompt answer. But I have a question. The function codes that you have for example in the Max Temperature or Min or in the average are arbitrary ( so I can change with whatever function code I want or you follow a manual ? ). Thank you!!
