i want to give a command as a string,after sending command in string format it appears as hexadecimal format in description.
on request sequence, command line is given as follows
<?xml version="1.0" encoding="utf-8" ?>
- <DevTemplate>
- <ElemGroups>
- <ElemGroup name="Temperature" tableType="HoldingRegisters" address="99">
<Elem name="process" type="ushort" byteOrder="" />
</ElemGroup>
- <ElemGroup name="realval" tableType="HoldingRegisters" address="109">
<Elem name="temp" type="float" byteOrder="" />
</ElemGroup>
- <ElemGroup name="setpoint" tableType="HoldingRegisters" address="299">
<Elem name="sp" type="ushort" byteOrder="" />
</ElemGroup>
- <ElemGroup name="stringval" tableType="HoldingRegisters" address="2079">
<Elem name="name" type="ushort" byteOrder="" />
</ElemGroup>
what is the command did i configure to enter command in string format
