Ok I’ll look deeper how is it later, thank you.
Thanks jacklondon.
I updated the github, I added the linux compatibility. Follow carefully README steps to make it properly. Also, after tests, I found what and how DLLs must be in the project. So it’s in the repo and explained how to manage them. At this point, normally, you would be able to make your own KpOpcUA without problem and windows and linux.
