Forum Home › Forums › Installation Issues › SCADA-Web Installation › Server is unavailable
- This topic has 38 replies, 6 voices, and was last updated 2 months, 1 week ago by Mikhail.
June 15, 2018 at 3:11 pm #3839tom040264Participant
I tried to solve the problem by using of this tread but without any successes. For 20 minutes everything worked perfect and I did some changes in the ComServer (I tried to add a command). Then I tried to load the SCADA-Page as usual, but I got the message “Server is unavailable.”
This is the WebSettings file:
<WebSettings>
<CommSettings>
<Param name=”ServerHost” value=”localhost” descr=”SCADA-Server host or IP address” />
<Param name=”ServerPort” value=”10000″ descr=”SCADA-Server TCP port number” />
<Param name=”ServerUser” value=”ScadaWeb” descr=”User name for the connection” />
<Param name=”ServerPwd” value=”12345″ descr=”User password for the connection” />
<Param name=”ServerTimeout” value=”10000″ descr=”Response timeout, ms” />
</CommSettings>
<CommonParams>
<Param name=”Culture” value=”” descr=”Web application culture” />
<Param name=”DataRefrRate” value=”1000″ descr=”Current data and events refresh rate, ms” />
<Param name=”ArcRefrRate” value=”10000″ descr=”Archive data refresh rate, ms” />
<Param name=”DispEventCnt” value=”100″ descr=”Display events count” />
<Param name=”ChartGap” value=”90″ descr=”Distance between chart points to make a gap, sec” />
<Param name=”StartPage” value=”” descr=”Start page after login” />
<Param name=”CmdEnabled” value=”true” descr=”Enable commands” />
<Param name=”CmdPassword” value=”true” descr=”Require password to send command” />
<Param name=”RemEnabled” value=”true” descr=”Allow to remember logged on user” />
<Param name=”ViewsFromBase” value=”true” descr=”Load view settings from the database” />
<Param name=”ShareStats” value=”true” descr=”Share depersonalized stats with the developers” />
</CommonParams>
<ScriptPaths>
<Script name=”ChartScript” path=”~/plugins/ChartPro/js/chartdialog.js” />
<Script name=”CmdScript” path=”~/plugins/Table/js/cmddialog.js” />
<Script name=”EventAckScript” path=”~/plugins/Table/js/eventackdialog.js” />
</ScriptPaths>
<Plugins>
<Plugin fileName=”PlgChart.dll” />
<Plugin fileName=”PlgChartPro.dll” />
<Plugin fileName=”PlgConfig.dll” />
<Plugin fileName=”PlgRegistration.dll” />
<Plugin fileName=”PlgSchBasicComp.dll” />
<Plugin fileName=”PlgScheme.dll” />
<Plugin fileName=”PlgStore.dll” />
<Plugin fileName=”PlgTable.dll” />
<Plugin fileName=”PlgWebPage.dll” />
</Plugins>
</WebSettings>The CPU load of ScadaServerSvc.exe is 0.
Any idea?June 15, 2018 at 4:37 pm #3841MikhailModeratorSee the log of the Server
C:\SCADA\ScadaServer\Log\ScadaServerSvc.logand the log of the web app
C:\SCADA\ScadaWeb\log\ScadaWeb.logJune 15, 2018 at 4:52 pm #3843tom040264ParticipantScadaServerSvc.log:
2018-06-15 16:43:17 <HP-SERVER><SYSTEM><ACT> ScadaServerService 5.1.0.3 is started
2018-06-15 16:43:19 <HP-SERVER><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2018-06-15 16:43:19 <HP-SERVER><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2018-06-15 16:43:22 <HP-SERVER><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 10
2018-06-15 16:43:22 <HP-SERVER><SYSTEM><ACT> Ouput channels are read from the configuration database
2018-06-15 16:43:22 <HP-SERVER><SYSTEM><ACT> Users are read from the configuration database
2018-06-15 16:43:22 <HP-SERVER><SYSTEM><ACT> Formulas are read from the configuration database
2018-06-15 16:43:23 <HP-SERVER><SYSTEM><ERR> Error compiling the source code of the formulas:
Line 523, column 55: error CS1501: Keine Überladung für die Methode ‘GetBit’ nimmt 1-Argumente an.
Line 526, column 55: error CS1501: Keine Überladung für die Methode ‘GetBit’ nimmt 1-Argumente an.
Line 529, column 56: error CS1501: Keine Überladung für die Methode ‘GetBit’ nimmt 1-Argumente an.
2018-06-15 16:43:23 <HP-SERVER><SYSTEM><ERR> Normal program execution is impossible.
2018-06-15 18:44:08 <HP-SERVER><SYSTEM><ACT> ScadaServerService is stopped
2018-06-15 18:44:08 <HP-SERVER><SYSTEM><ACT> ScadaServerService 5.1.0.3 is started
2018-06-15 18:44:09 <HP-SERVER><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2018-06-15 18:44:09 <HP-SERVER><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2018-06-15 18:44:09 <HP-SERVER><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 10
2018-06-15 18:44:09 <HP-SERVER><SYSTEM><ACT> Ouput channels are read from the configuration database
2018-06-15 18:44:09 <HP-SERVER><SYSTEM><ACT> Users are read from the configuration database
2018-06-15 18:44:09 <HP-SERVER><SYSTEM><ACT> Formulas are read from the configuration database
2018-06-15 18:44:09 <HP-SERVER><SYSTEM><ERR> Error compiling the source code of the formulas:
Line 523, column 56: error CS1501: Keine Überladung für die Methode ‘GetBit’ nimmt 1-Argumente an.
2018-06-15 18:44:09 <HP-SERVER><SYSTEM><ERR> Normal program execution is impossible.ScadaWeb.log
2018-06-15 18:17:11 <HP-SERVER><DefaultAppPool><ACT> Initialize common web application data
2018-06-15 18:17:11 <HP-SERVER><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2018-06-15 18:17:12 <HP-SERVER><DefaultAppPool><EXC> Error connecting to SCADA-Server: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:10000
2018-06-15 18:17:12 <HP-SERVER><DefaultAppPool><ACT> Disconnect from SCADA-Server
2018-06-15 18:17:12 <HP-SERVER><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
Scada.ScadaException: Unable to receive the configuration database modification time.
bei Scada.Client.DataCache.RefreshBaseTables()
2018-06-15 18:17:12 <HP-SERVER><DefaultAppPool><ACT> User information has been added. IP address: 91.113.32.125. Session: fmn4stqwwpvgopgm52hkwfpw
2018-06-15 18:17:12 <HP-SERVER><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2018-06-15 18:17:12 <HP-SERVER><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 91.113.32.125
2018-06-15 18:17:14 <HP-SERVER><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2018-06-15 18:17:14 <HP-SERVER><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 91.113.32.125
2018-06-15 18:37:20 <HP-SERVER><DefaultAppPool><ACT> User information has been removed. IP address: 91.113.32.125. Session: fmn4stqwwpvgopgm52hkwfpw
2018-06-15 18:38:24 <HP-SERVER><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2018-06-15 18:38:25 <HP-SERVER><DefaultAppPool><EXC> Error connecting to SCADA-Server: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:10000
2018-06-15 18:38:25 <HP-SERVER><DefaultAppPool><ACT> Disconnect from SCADA-Server
2018-06-15 18:38:25 <HP-SERVER><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2018-06-15 18:38:25 <HP-SERVER><DefaultAppPool><ACT> User information has been added. IP address: 127.0.0.1. Session: 5h2nvzvuesmbbumghftk20vm
2018-06-15 18:38:33 <HP-SERVER><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2018-06-15 18:38:33 <HP-SERVER><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2018-06-15 18:38:33 <HP-SERVER><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 127.0.0.1“Unable to connect because the destination computer refused the connection 127.0.0.1:10000”
June 16, 2018 at 5:31 pm #3849MikhailModeratorLine 523, column 56: error CS1501: Keine Überladung für die Methode ‘GetBit’ nimmt 1-Argumente an.
See the file C:\SCADA\ScadaServer\Log\CalcEngine.cs with the source codeOpen CalcEngine.cs and go to Line 523, column 56
Probably you inccorctly use GetBit function.
All the formulas from Administrator are included in CalcEngine.cs. You should fix the formula in Administrator.June 16, 2018 at 5:32 pm #3850MikhailModeratorServer cannot start correctly, that’s why the web app doesn’t connect to it.
June 17, 2018 at 7:57 am #3855tom040264ParticipantI fixed the formula, and it works now. Thank you!
December 7, 2020 at 12:02 pm #7678mark9966ParticipantGood morning,
I have installed rapid scada on my win10 local machine and everything works. Then to have it accessible via internet i installe it on a windows server 2019 google cloud VM. When i try to login –> server is unavailable. No log file on the agent.
How can i fix this?
December 7, 2020 at 1:05 pm #7679mark9966Participanthttps://postimg.cc/zV9JMWpQ what i get
December 8, 2020 at 5:29 am #7681MikhailModeratorThe Agent service doesn’t work. If you need more info, create a new topic.
March 29, 2023 at 3:07 pm #12321TDEParticipantHi,
How to solve this problem
Cordially
https://drive.google.com/file/d/1OfIluDY2B2QYh88udcjgVVqbt6n9sz2o/view?usp=share_link
March 30, 2023 at 8:26 am #12324MikhailModeratorHi,
The above link is not public.February 7, 2024 at 9:50 am #14012KeanoCParticipantIm experiencing a similar issue where when I try logging in to the websation it says server unavailable and the instance manager is showing that the status is not supported but I receantly migrated from 5.4.1 to v6
February 7, 2024 at 10:52 am #14013MikhailModeratorThe web app does not show its status, therefore it’s written that it is not supported. To fix the issue, check log files of the applications.
February 7, 2024 at 11:08 am #14017KeanoCParticipantError connecting to SCADA-Server: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
This is the error I find in the logs how do I fix this?
February 8, 2024 at 8:54 am #14020MikhailModeratorRestart SCADA-Server, then check ScadaServer.log. Copy start messages from the log here.
