Thanks, Manjey n Mikhail… It really helped. Now that I got to know that we can write our own script in RapidScada. It’s really helpful.
Meanwhile, i tried a bit on my own for generating reset output. I wrote a script wherein, the output is 1 for a specified duration and then it gets to zero. But I am facing a difficulty.
The input parameter for the function is a coil channel read via Modbus from the Modbus device. Is there any way to set the values of output/Input channel dynamically through a code??? I tried with CnlValSet(Int Cnl, Double Value) & SetVal(Int Cnl, Double Value) But I am getting an error with it…
Line 496, column 1: error CS0103: The name ‘CnlValSet’ does not exist in the current context
Below is the snippet of the code I am using. The algorithm which I intend to use is that if the value of coil register is 1, then the function will return value of 1 for 5 seconds and then it will return zero. Then I’ll make the value of coil register to zero inside the function itself to reset it.
bool Getreset (bool a,int InCnl )
// bool a is the value of coil register
int result;
DateTime now = DateTime.Now;
DateTime now2 = now.AddSeconds(5);
if (a==Convert.ToBoolean(1))
do
result = DateTime.Compare(DateTime.Now, now2);
if (result < 0)
return (Convert.ToBoolean(1));
else
return (Convert.ToBoolean(0));
} while (result < 0);
CnlValSet(Incnl,0);
else
return(a);
