Thank you very much, this was the problem.
We’ve created a Virt. Channel 32 – Discrete, which reads the device input 9.
And we’ve filled out each virtual channel per bit, with the GetBit(Val(9),n)
And this works! Tested with several open/closed
We didn’t enum text it yet. As i wanted to see the value.
Up to the next challenge, read out aprox 20x Current (0-20mA) sensor channels into Scada. (Thinking of raspberri/adruino via i2c and tranport via modbusTCP)
This reply was modified 5 years, 5 months ago by IncineratorX2.
This reply was modified 5 years, 5 months ago by IncineratorX2. Reason: image links broken
