I am trying to write the values to the manipulating variable (Final Control Element) like control valves. I want to define low/high limit values to the same tag.
Example:
I wanted to write a value to the tag valve position=22
Low Limit of valve=20
High Limit of valve = 30
when I write valve position=35 for example
It should be sent 30 since it is a High Limit
when I write valve position=15 for example
It should be sent 20 since it is a Low Limit
This topic was modified 2 years ago by arunagiri.
