Database SQL usage Forum Home › Forums › Development and Integration › Database SQL usage Tagged: SQL This topic has 18 replies, 3 voices, and was last updated 2 years, 7 months ago by Nguyen. Viewing 4 posts - 16 through 19 (of 19 total) ← 1 2 Author Posts June 23, 2021 at 12:14 pm #9150 MikhailModerator Hi, May be the new DB export module can help you. But I’m not sure that it’s compatible with your version of Rapid SCADA. And there is no manual for the module. Anyway, let’s try. August 1, 2021 at 2:07 am #9321 HanParticipant Hi, I have been busy with other things recently. Which version of Rapid SCADA is needed? August 3, 2021 at 12:30 pm #9325 MikhailModerator Hi, 5.8.3 I think, 5.8.2. If needed, it the module can be updated to be compatible with 5.8.3. This reply was modified 2 years, 7 months ago by Mikhail. August 25, 2021 at 2:55 am #9424 NguyenParticipant Hi. Did you solve your problem? I have got the same problem with you. Author Posts Viewing 4 posts - 16 through 19 (of 19 total) ← 1 2 You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
