You can see the statuses in the Event types table.
5 is Unreliable
It means that there are no data for a period (by default 5 mins). You should check if Communicator works or not.
Communicator status is ok… but there is no change in data, but this is a normal condition for this case, and it should not be changed to 5 … is it possible.?
