Automatic Control Issue
Forum Home Forums Understanding the Software Automatic Control Issue
Viewing 3 posts - 16 through 18 (of 18 total)
  • #6066
    AvatarKrzysztof
    I restart the server and send the configuration very often, because I work a lot on this Rapid Scada instance. Status before alarm 13, after 15. At the moment I can tell that it does not work only with calc real. Earlier I tried to refer to val (7239), but it did not work well, so I moved to a reference to status and in this case it does not work at all. I will experiment on a test instance and we will see that I can determine. Meanwhile, I’m putting my module config. Maybe I demand too much of him.
    #6067
    AvatarKrzysztof
    MikhailMikhail
    I can’t download the zip, but I think it’s not necessary. Number of triggers doesn’t matter.
    Let’s choose a one of the following ways:
    1. Create as simple project as possible and find how to reproduce the problem without real devices. So I can do fix the bug on my PC.
    2. Remote trobleshooting as a paid service.
