Forum Home › Forums › New Ideas › about SCADA V6
- This topic has 22 replies, 5 voices, and was last updated 3 years ago by Mikhail.
March 29, 2021 at 7:13 am #8585zzzParticipant
Sql version control tools: https://dbmstools.com/categories/version-control-tools/postgresql
- This reply was modified 3 years ago by zzz.
March 29, 2021 at 2:16 pm #8590MikhailModeratorIf we found a sponsor, we can implement uploading a project from Administrator to PostgreSQL database.
In my opinion, SQLite is not enough, because remote access is quite useful in many cases.March 30, 2021 at 2:51 am #8595zzzParticipantIn my opinion, SQLite is not enough, because remote access is quite useful in many cases.
If its ORM based. SQLite is just the RDBMS backends for minimum setup. User can change to other choice at their will. Nowadays many db backed projects don’t require particular backends.
I use python more often. I can do export with pythonnet.
But programatically manipulating many configuration with sql is much easier than manipulating many xml files directly.Let’s say there is a project with 50 machines, each machine with 10 different sensor of 7 different types and 2 control module. The channel numbers are referened in formulas. Each sensor type has a unique formula.
If this project configuration is in a RDBMS, one can write a simple script with 2 loops to populate entries into the database InChannel and related table.
Changed mind on the channel numbering scheme? Modify a few line of code, TRUNCATE and reINSERT into the database, instead of messing with all the xml files and UI entries.
Update one particular type of sensor’s setup on all machines? Use 1 UDPATE state with proper condition, instead of editing in UI or search/replace with great caution in a text editor.
The previous method’ results are consistent, even errors are likely to be easier to spot due to that consistency. Errors in latter case methods are random and hard to spot.
The ability to do simple scripting easily, can bring great relife on inital project setup for real-life scaled project. And RDBMS with clean schema make that naturally available.
March 30, 2021 at 2:40 pm #8609MikhailModeratorIn Rapid SCADA v4 we used MSSQL Compact for storing configuration database. It is very close to SQLite. This approach was so inconvenient. I agree that SQL is a powerful language, but comparing pros and cons, the file based projects that can be easily uploaded and downloaded are preferable.
It’s possible to use an RDBMS instead of BaseDAT\*.dat as a runtime data source. We will implement it if found a sponsor.
March 31, 2021 at 11:37 am #8611ZeusParticipanthi
will the v6 use blazor?
there is a project ant-design-blazor.
it is a good idea to use this project.
https://github.com/ant-design-blazor/ant-design-blazorMarch 31, 2021 at 12:54 pm #8612MikhailModeratorHi,
We already made a mistake when developed on Silverlight. I guess, Blazor is an reincarnation of Silverlight ))April 1, 2021 at 12:23 am #8615ZeusParticipantHi,
you are right.
there is no much developer using blazor.
the best way may be Vue React or AnjularApril 1, 2021 at 12:51 pm #8625MikhailModeratorHi,
The mentioned frameworks are good.
The choice between single page application and multi page application. Every approach has has its own advantages and disadvantages. Will see.
