OPC write value issue-IBH opc server
Forum Home › Forums › Communicating with Devices › OPC › OPC write value issue-IBH opc server
Viewing 8 posts - 91 through 98 (of 98 total)
  • #4676
    mariodavid
    Why you don’t pass valid URL to new OpcCom.Da20.Server(url, server)?
    Becase I do not what is a valid URL. Could be “http://localhost/Scada/”? I really do not know.
    Interface is just a declaration. The runtime executes the method of an object that was actually created.
    I am trying to create a class derived from IOPCSyncIO interface. Implementing Something like this:
    “private IOPCSyncIO campo;
    public IdentifiedResult[] Write(ItemValue[] items)
    if (this.campo == null)
    throw new NotConnectedException();
    ((IOPCSyncIO) this.campo).Write(items);
    without return, because IOPCSyncIO.write is void method
    but give me a NullReferenceException
    I am trying to create a instance of a interface, but that is not possible.
    #4677
    mariodavid
    Becase I do not KNOW what is a valid URL. Could be “http://localhost/Scada/”? I really do not know.
    Excuse my mistakes when writing
    #4678
    mariodavid
    I have passed all kinds of values to url: int, boolean, string. The compiler said that: can not be changed to an OPC.URL type.
    URL url = 12;
    URL url = “nashghda”;
    URL url = true;
    Only allows URL url = null;
    Do you know which is the valid URL to new OpcCom.Da20.Server(url, server)?
    #4684
    I suppose the URL here is the ID of the OPC server, e.g. Matrikon.OPC.Simulation/{f8582cf2-88fb-11d0-b850-00c0f0104305}
    #4685
    mariodavid
    I tried this Opc.URL url = new Opc.URL(“”); Compile without error but appers: error sending command: remote server is not currently connected. There is no exception in the contructor with this meaning. Where do you think is the exception?. I probe it with “localhost” etc. Still the same error
    #4690
    Is there a method like Connect to connect to the OPC server?
    #5766
    danielfernandes
    I am using Kepware software for middleware with PLC Omron. The kepware implement the OPC server.
    I already can communicate and I read the memory positions of Plc.
    Now, I want write in this positions of Plc, but I don’t understand how I can doing.
    Can you help me?
    #5767
    Please create a new topic in https://forum.rapidscada.org/?forum=communicating-with-devices/opc
    This topic is not relevant to the question.
    Provide information what Rapid SCADA version do you use?
    Did you do some settings to write data or have no idea how to do it?
