Forum Home › Forums › Communicating with Devices › OPC › OPC write value issue-IBH opc server
- This topic has 97 replies, 3 voices, and was last updated 7 years, 3 months ago by
November 28, 2018 at 5:09 pm #4676
mariodavid
ParticipantWhy you don’t pass valid URL to new OpcCom.Da20.Server(url, server)?
Becase I do not what is a valid URL. Could be “http://localhost/Scada/”? I really do not know.
Interface is just a declaration. The runtime executes the method of an object that was actually created.
I am trying to create a class derived from IOPCSyncIO interface. Implementing Something like this:
“private IOPCSyncIO campo;
public IdentifiedResult[] Write(ItemValue[] items)
if (this.campo == null)
throw new NotConnectedException();
((IOPCSyncIO) this.campo).Write(items);
without return, because IOPCSyncIO.write is void methodbut give me a NullReferenceException
I am trying to create a instance of a interface, but that is not possible.
November 28, 2018 at 5:34 pm #4677mariodavid
Becase I do not KNOW what is a valid URL. Could be “http://localhost/Scada/”? I really do not know.
Excuse my mistakes when writing
November 29, 2018 at 12:45 am #4678mariodavid
ParticipantI have passed all kinds of values to url: int, boolean, string. The compiler said that: can not be changed to an OPC.URL type.
URL url = 12;
URL url = “nashghda”;
URL url = true;Only allows URL url = null;
Do you know which is the valid URL to new OpcCom.Da20.Server(url, server)?
November 29, 2018 at 6:11 pm #4684
MikhailModeratorI suppose the URL here is the ID of the OPC server, e.g. Matrikon.OPC.Simulation/{f8582cf2-88fb-11d0-b850-00c0f0104305}
November 29, 2018 at 11:47 pm #4685mariodavid
ParticipantI tried this Opc.URL url = new Opc.URL(“”); Compile without error but appers: error sending command: remote server is not currently connected. There is no exception in the contructor with this meaning. Where do you think is the exception?. I probe it with “localhost” etc. Still the same error
November 30, 2018 at 4:06 pm #4690
MikhailModeratorIs there a method like Connect to connect to the OPC server?
July 30, 2019 at 12:39 pm #5766danielfernandes
ParticipantHello,
I am using Kepware software for middleware with PLC Omron. The kepware implement the OPC server.
I already can communicate and I read the memory positions of Plc.
Now, I want write in this positions of Plc, but I don’t understand how I can doing.
Can you help me?July 30, 2019 at 2:17 pm #5767
Please create a new topic in https://forum.rapidscada.org/?forum=communicating-with-devices/opc
This topic is not relevant to the question.Provide information what Rapid SCADA version do you use?
Did you do some settings to write data or have no idea how to do it? -
