OPC write value issue-IBH opc server
Forum Home › Forums › Communicating with Devices › OPC › OPC write value issue-IBH opc server
Viewing 15 posts - 76 through 90 (of 98 total)
  • #4584
    mariodavid
    thank you, I managed to debug but I wanna see the method inside. Said that the simbols are not charged.
    https://imgur.com/a/mU22iFe
    I just realize than “public override IdentifiedResult[] Write(ItemValue[] items)” belong to a class,
    which is derived from another class That contain “public virtual IdentifiedResult[] Write(ItemValue[] items)”.
    So, the next method
    public IdentifiedResult[] Write(ItemValue[] items)
    if (this.m_server == null)
    throw new NotConnectedException();
    return ((IServer) this.m_server).Write(items);
    calls “public virtual IdentifiedResult[] Write(ItemValue[] items)” but why does not call override method too?
    Is necesary to create a new class like you said?
    I have another doubt. “((IOPCSyncIO) this.m_group).Write” only happens if (arrayList1.Count > 0)?
    if (items == null)
    throw new ArgumentNullException(nameof (items));
    if (items.Length == 0)
    return new IdentifiedResult[0];
    lock (this)
    Item[] items1 = new Item[items.Length];
    for (int index = 0; index < items.Length; ++index)
    items1[index] = new Item((ItemIdentifier) items[index]);
    IdentifiedResult[] items2 = this.AddItems(items1);
    try
    ArrayList arrayList1 = new ArrayList(items.Length);
    ArrayList arrayList2 = new ArrayList(items.Length);
    if (!items2[index].ResultID.Failed())
    if (items[index].QualitySpecified || items[index].TimestampSpecified)
    items2[index].ResultID = ResultID.Da.E_NO_WRITEQT;
    items2[index].DiagnosticInfo = (string) null;
    else
    arrayList1.Add((object) items2[index]);
    arrayList2.Add((object) items[index]);
    int[] phServer = new int[arrayList1.Count];
    object[] pItemValues = new object[arrayList1.Count];
    for (int index = 0; index < phServer.Length; ++index)
    phServer[index] = (int) ((ItemIdentifier) arrayList1[index]).ServerHandle;
    pItemValues[index] = OpcCom.Interop.GetVARIANT(((ItemValue) arrayList2[index]).Value);
    IntPtr ppErrors = IntPtr.Zero;
    try
    ((IOPCSyncIO) this.m_group).Write(arrayList1.Count, phServer, pItemValues, out ppErrors);
    catch (Exception ex)
    throw OpcCom.Interop.CreateException(“IOPCSyncIO.Write”, ex);
    int[] int32s = OpcCom.Interop.GetInt32s(ref ppErrors, arrayList1.Count, true);
    for (int index = 0; index < arrayList1.Count; ++index)
    IdentifiedResult identifiedResult = (IdentifiedResult) arrayList1[index];
    identifiedResult.ResultID = OpcCom.Interop.GetResultID(int32s[index]);
    identifiedResult.DiagnosticInfo = (string) null;
    if (int32s[index] == -1073479674)
    items2[index].ResultID = new ResultID(ResultID.Da.E_READONLY, -1073479674L);
    finally
    this.RemoveItems(items2);
    return items2;
    #4585
    mariodavid
    https://imgur.com/a/frs1iEY
    public override IdentifiedResult[] Write(ItemValue[] items) in OpcCom.Da20.Server
    public virtual IdentifiedResult[] Write(ItemValue[] items) in OpcCom.Da.Server
    I really do not understand how to call override write method.
    #4586
    Because this method belongs to another DLL. If you need to debug this method, attach open the source code of the appropriate DLL.
    #4587
    You should create an instance of your own class instead of the parent class.
    #4591
    mariodavid
    I tried to create a class, declaring a field to call override method. Also changing KpOpclogic. Compiled without error.
    https://imgur.com/a/czTSOLI
    But, when I run communicator, shows a error. “An object of type Op.Da.Server can not be converted to the type Scada.Comm.KP.Class2”
    https://imgur.com/a/wVA1ThC
    #4592
    mariodavid
    I also tried to create a project with OpcNetApi but when i compiled shows 2 errors.
    With OpcNetApi.com, compiled wiht no error, attach to the process but can not set break points because the symbols can not be charged.
    #4595
    These errors are very specific. To find answers I should do all this stuff by myself. I hope you can find out how to solve it.
    I recommend to catch the exception and write to log complete stack trace. Something like that:
      WriteToLog(ex.ToString());
    #4597
    mariodavid
    I have another idea, but i need to know how to open a project of OpcNetApi and OpcNetApi.Com.dll in VS 2017. Can you tell me how do you use those dll to debug in VS? Please. Do you have the folder like KpOpcSource that i can use?
    #4601
    I have no source code of OpcNetApi. Does a decompier, that you use, can create a VS project that can be build for debug?
    #4602
    mariodavid
    Yes, I open projects with dotpeek but whe i compiled, give some errors.
    I also tried to call override method using a field like this
    private OpcCom.Da20.Server campo;
    compiled without errors. I run the communicator, trying to send a command give this error:
    “Error sending command: Object reference not set to an instance of an object”.
    Can you give some template o examples to create a instance in KpOpclogic class?
    #4603
    mariodavid
    I am trying this:
    private OpcCom.Da20.Server campo = new OpcCom.Da20.Server();
    but give me this error: CS7036 C# There is no argument given that corresponds to the required formal parameter ‘url’ of ‘Server.Server(URL, object)ยด
    #4608
    Could you clarify what example do you need?
    #4670
    mariodavid
    Hi
    I am tryng to call override method using this.
    URL url = null;
    object server = null;
    OpcCom.Da20.Server campo = new OpcCom.Da20.Server(url, server);
    campo.Write(new Opc.Da.ItemValue[] { itemVal });
    Compiled witout error. When I run communicator, appers this error: error sending command: url can not be null.
    I can not change url to another value. So, Can not I use this method definitly?
    Where else can I do with url?
    #4671
    mariodavid
    In the original KpOpcLogic, you use:
    daServer.write(new Opc.Da.ItemValue[] { itemVal });
    Going to write method declaration:
    public class Server : Opc.Server, IServer, Opc.IServer, IDisposable
    So, “m_server.write” calls write method of IServer. but IServer is a interface. Why does not call a implementation of IServer instead?
    #4675
    Why you don’t pass valid URL to new OpcCom.Da20.Server(url, server)?
    This URL is needed to specify the server you connect.
    Interface is just a declaration. The runtime executes the method of an object that was actually created.
