OPC write value issue-IBH opc server
Forum Home › Forums › Communicating with Devices › OPC › OPC write value issue-IBH opc server
Viewing 15 posts - 61 through 75 (of 98 total)
  • #4555
    mariodavid
    Hi
    Searching the implementation of da.server.write:
    You used this method
    https://imgur.com/a/LrHcSac
    And please take a look closely to this screenshots. There is a implementation of da.write
    https://imgur.com/a/tVte9KD
    https://imgur.com/a/idmZjhe
    this is a pubic override method
    How can this override writeVQT methods?
    • This reply was modified 7 years, 11 months ago by mariodavid.
    #4557
    Create a new class that is derived from the Server class and override Write method.
    Can you try this?
    #4559
    mariodavid
    Yes. I can try. But I open kpOpc project in visual studio and shown 6 error and 82 warnings.
    https://imgur.com/a/n1586Bu
    #4560
    mariodavid
    #4561
    mariodavid
    I managed to open without errors. only shows warnings
    I am tryng to create a class called “serverNew” from OpcCom.Da20.Server class. I know that serverNew inherits all the methods of OpcCom.Da20.Server class. So that, that include IOsyncIO:write method. So, What is inside new class?
    https://imgur.com/a/9qG905q
    #4563
    mariodavid
    Sorry sorry. The idea is create a class derived from Server (include writeVQT) and add “public override write(IOsyncIO:write)” to the new class. Right?
    But, how do I include public override write?
    I am trying this
    namespace OpcCom.Da
    public class serverNew : OpcCom.Da.Server
    public IdentifiedResult[] Write(ItemValue[] items)
    if (this.m_server == null)
    throw new NotConnectedException();
    return ((????)this.m_group).Write(items);
    m_group execute public override write but is private object. So i can use it in another class. I am stop here.
    How can i debugg librarys in visual studio?. It ask me to reference the library to an aplication that uses that library.
    #4565
    At the moment, can you successfully compile KpOpc? First of all, you need to fix build errors if they still exist. Possible cause is broken references.
    #4566
    The idea to override a method is right. Details depend on you.
    1. Build a library in Debug configuration.
    2. Copy DLL to Communicator and Run Communicator as usual.
    3. In VS go to Debug – Attach to Process and choose ScadaCommSvc.exe
    #4567
    mariodavid
    Hi
    What version of VIsual STUDIO should I use? I have trouble loading the symbols in VISUAL STUDO 2017. So I can not establish breakpoints or debugging step by step
    #4571
    I use VS 2017 Community Edition.
    DLL must be compiled in Debug configuration. It’s located in bin\Debug
    #4573
    mariodavid
    How do I stop opening a KpOpc project with VS? I only open the dll with DOTPEEK and export to VS. I open the project, compile, without errors. Copy the KpOpc.dll generated in bin / debug and paste it into SCADAcomm / KP. break point in:
    this.daServer.Write(new ItemValue[1]
    itemValue
    Attach to Process and choose ScadaCommSvc.exe. But whe I use SCADA.Communicator to write matrikon tags, does not stop in
    itemValue
    What am i doing wrong?
    https://imgur.com/a/Y6HZ9cH
    #4576
    1. After compile KpOpc you should find KpOpc.dll in bin\Debug. Not put it here, but the compiler creates it.
    2. Copy KpOpc.dll from bin\Debug to C:\SCADA\ScadaComm\KP
    3. Start Communicator service.
    4. Attach to ScadaCommSvc.exe process in VS.
    Then breakpoints should work.
    #4579
    Set a breakpoint in the beggining of the SendCmd method.
    Why you did not compile the source of KpOpc which I shared?
    #4580
    mariodavid
    Hi, because i do not how to use it. I do not how to open a proyecto with that file. I justo use jetbrains dotpeek, open a DLL and export to visual studio proyecto. Can you tell me how can i use the source kpopc that you shared?
    #4583
    I’ll try to help you. Open the project KpOpc.csproj in VS2017. Check references node in Solution Explorer to make sure that all assemblies are found. Run Build and make a screenshot if there are errors.
